Question about GE Microwave Ovens
Melted shelf bracket
Three of the plastic shelf brackets have melted
4 Suggested Answers
  • 5 Answers
SOURCE: jvm 1650 burned one of the mounting brackets
The mounting brackets don't have electricity in them, it has to be an internal short in the oven. It should be taken down and opened up to determine what happened. If the damage is too severe the oven probably would have to be replaced. I would take it to a repair center and get it diagnosed and see if it is something simple that won't cost a lot of money.
Posted on Dec 26, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: removal of unit from wall bracket
You can download GE installation instructions here.
Then you can see how it went up to help you get it down.
Posted on Nov 27, 2008
  • 1891 Answers
SOURCE: Trying to remove my Sharp R1830 microwave. We
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Posted on Jan 10, 2010
Testimonial: "Thanks so much...appreciate your help. The old microwave is now off and a new one in its place! Thanks again!"
What model would be equal to a sharp microwave model R1490
Chances are only an identical model will fit the brackets. Any new unit will come with new brackets. Just swap the brackets out and install the new unit
Oct 16, 2016 | Sharp Microwave Ovens
What glue do i use to repair a broken microwave \shelf bracket
Donna, I would use crazy glue or similar strong glue. I think it should be safe but read instructions.
Mar 19, 2014 | Microwave Ovens
Shooting sparks out left side near bracket for shelf
if there are any sparks inside the cabinet it is time to throw the microwave out or send it out for a powder paint $$$$$$
Nov 27, 2013 | Kenmore Microwave Ovens
My microwave want work unless I hold the door shut. What parts would I need to replace?
You will likely need interlock switches and the brackets to hold them. Brackets are usually made of plastic and can crack. The switches can sometimes fail where they require more force to make a connection. Remember to unplug the power and discharge the capacitor before working on any microwave.
Sep 09, 2013 | Microwave Ovens
Having difficulty getting old spacemaker oven out in order to install new.
There are two screws coming into the top front accessed inside the cabinet it is mounted to. the rear of the unit is hung on clips on the bracket screwed to the wall behind it. Take out the two screws ( sometimes hidden under paint or shelf liner) and have someone hold the front up. Then push up on the whole oven and pull it out towards you. ( get help it is kind of heavy). dont forget to unplug it, and feed the cord down as you pull the microwave out. sometimes you have to pull hard, as the pins on the bracket get bent during installation.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Trying to remove my Sharp R1830 microwave. We removed the top screws (into the shelf above) and the thumb screws at the bottom of the microwave that clip into the back wall bracket; but the clips seem to...
Jan 09, 2010 | Sharp R-1480 Microwave Oven
My frigidaire microwave door is sagging and is about to fall off
EASY get a machine screw, nut with washer. I believe I used a 1/8" machine screw.....(find something small to fit in the hole on the bottom hinge.
First step, take 3 screws off bottom to expose hinge area. Have someone hold it or support it so wires to the light do not pull out,.
Pop the machine screw through the front and then with your fingers get the washer an nut and tighten down.
If you want the professsional look. Paint the machine screw white first with a enamel white paint.
Sep 03, 2009 | Frigidaire PLMV169DC Microwave Oven
Over the range microwave
you remove the three screws at the top that hold the black plastic grill, then you will see two flat-bladed screw heads, when you turn those, they unlock. Be careful, it's heavy! You bring it down then lift from the back.
Dec 29, 2007 | Microwave Ovens
Jvm 1650 burned one of the mounting brackets
Dec 25, 2007 | GE JVM1650 1000 Watts Microwave Oven
Sparking fire inside the microwave - Knemore Model No. 721.80522500
If the sparking has stopped, that should be fine.
If you have a burned spot you may need to sand it and repaint it with appliance paint from Wal-Mart, etc.
You can probably replace the shelf bracket / hook if it's still available.
If you'll post your brand and model, we'll see if we can steer you toward a source for a new shelf bracket.
If it's a Kenmore, you can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 07, 2007 | Microwave Ovens
Microwave Ovens Logo
20 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
