Question about Apex Digital LD4086 LCD TV
How do i enter the servicemenu - Apex Digital LD4086 LCD TV
Servicemenu
Press [display] key on the remote handset and button on tv set, simoultaniously. "serv" will be displayed on screen to indicate that the tv is now in service mode. To get more details, http://electronicshelponline.blogspot.com/. Service mode entry, adjust and exit procedure to many popular TVs are given in detail.
Nov 17, 2013 | Sanyo Televison & Video
Hp laserjet p3005 68.1 error coming
The actual error says that the hard drive is bad. I bet that you don't have a hard drive on your printer, so read on...
From the manual
NVRAM initialization
CAUTION Initializing the NVRAM resets the serial number, the event log, the page counts, and
the EIO card (initializing the NVRAM resets SERVICEmenu values to factory defaults). Use the
service menu to restore the serial number and page counts. Also reconfigure any computers that
print to this device so that the computers can recognize the device. Initialize the NVRAM only
when absolutely necessary. In most situations, use a cold reset rather than a NVRAM initialization
to reset device settings (this will retain the values in the SERVICEmenu).
NOTE Before performing a NVRAM initialization, print a menu map and a configuration page
. Use the information on the configuration page to reset
any customer-set device configuration values that the NVRAM initialization procedure changes.
Take special note of the total page count, maintenance count, and the serial number.
1. Remove any installed accessories.
2. Turn the device off.
3. Turn the device on. When the memory count begins, press and hold the button. Continue
holding down the button until all three device control-panel lights flash once and then remain
on. This might take up to 10 seconds.
4. Press the button.
5. Press the Menubutton. The display should show SKIP DISK LOAD.
6. Press the button until NVRAM INITis highlighted.
7. Press . The device initializes NVRAM and then continues the power-on sequ
Jun 20, 2012 | HP LaserJet P3005n Printer
Low volume on sony nwz-e453 mp3
Here is the combination for the servicemenu: Back 1,5seconds Hold ON Right Left Volume UP Volume Down Right Left Option Back Option Back
Now it should restart, then set Hold to Off. Under Audio you can change the settings.
Remember to be careful.
Nov 24, 2010 | Sony Audio Players & Recorders
I have an rca true flat. how do I turn off the FPA lock?
push the volume - on the tv til its to minimum.then hold that button and push info button on the remote.
you come into the servicemenu. i think you can chance something like hotelmode.
Apr 08, 2010 | RCA TruFlat 27F520T 27" TV
When I start my TV it turns on with white screen, ''heatrun''.
set the sharpness on 0 and the program on 99
use the keys red,green,yellow
menu to exit
Apr 06, 2010 | Televison & Video
SC546
sc 546 is fuser fault!check the connection of fuser catridge or try this:turn on machine-enter the servicemenu-open front door-then power on/off-close front door---->this will restart your Ricoh
Apr 06, 2010 | Ricoh Aficio 1035 Copier
Reset the usage page on a 4345mfp
The only way to reset the total page count back to zero is from the service mode. Link for service code.
http://www.printertechs.com/tech/pin-servicemenu.php
Link for user guide, menu map under contol panel will show where service mode is.
http://www2.bvu.edu/departments/businessservices/infoservices/2fix/documents/manuals/lj4345userguide.pdf
Oct 14, 2009 | HP LaserJet 4345mfp Printer
TN55X81 Rear Projection color separation - convergence problem
You shouldn't need to do a board replacement, all you should need to do is manually tune the convergence.
You can do this with the built-in user tool, but there's also a far more powerful set of options in the service mode. To save you the trouble (I advise doing a LOT of reading before attempting any of this) here's a solid set of various tutorials based on what form of "separation" you have occurring:
http://www.keohi.com/keohiHDTV/brandspecific/toshiba/servicemenu/servicemenu.html
Nov 21, 2007 | Toshiba 55H70 55" Rear Projection...
Apex Digital LD4086 LCD TV Logo
24 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
