Question about Dell XPS 420 PC Desktop
When I push my power button on my xps 420 desktop the power will not come on
    Novelist:
  • 178 Answers
Either the on switch is broken, or if you get power lights on then it could be worse problems like your boot files are corrupted, graphics card damaged/failure, number of possibilities.
Posted on Apr 21, 2014
wildbear6
  • 192 Answers
SOURCE: My xps 420 pc desktop wont boot. Shut it down last
Try and reset your CMOS and see if it helps.
If you're not sure how, then unplug the power cable from your PC, then take off the side panel, on the motherboard is a set of 2 or 3 pins to Clear the CMOS (reset the BIOS) all boards are different, so there is no set location for the CMOS pins, if you're unsure, just remove the battery from the motherboard for about 30 seconds, then replace it ("+" facing up)
But you need to make sure your PS is not plugged into any external power source while you're doing this or you risk deleting your BIOS
Hope this helps in some way.
Posted on Jan 01, 2010
joecoolvette
  • 5660 Answers
SOURCE: My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Posted on Jan 04, 2010
  • 29 Answers
SOURCE: reset window vista
Dell has a program called zztop, you can find the utility here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R20457&SystemID=DIM_PNT_P03_XPS_T___&servicetag=&os=W98&osl=en&deviceid=1509&devlib=0&typecnt=0&vercnt=1&catid=&impid=&formatcnt=1&libid=7&typeid=-1&dateid=-1&formatid=-1&fileid=20307
there is a hidden partition ( you cant see it in windows nor will you be able to see it in most partition managers) that holds your original OS. Running zztop will put this image back on your comptuer.
Posted on Feb 01, 2010
  • 78 Answers
SOURCE: my dell xps 420 will not power on. power light
Hi
If your system's power light blinks amber, it means the computer is receiving electrical power, but an internal power problem might exist.
Do the following to tackle this issue:
  • If applicable, make sure that the voltage selection switch which is at the rear of your system matches AC power in your area.
  • Ensure that the power cable is securely connected to system board.
Here are links with pictures to assist you in opening the system and reconnecting the internal cables.
Please follow safety instructions before you perform these tasks. Here is a link, which gives you complete safety instruction.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372453
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372490
Next is to see the system board design. Here is the link.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1402834
and if you wish to research a bit more here is the link,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1076480
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1097292
Here you will find complete manuals for further research
If this does not resolve the issue, then the motherboard or processor is faulty and you need to get it replaced, so if your system is within warranty why pay extra, get it replaced from Dell. Else contact a local tech and he'll help you out.
Please rate as per the assistance level. Thanks :)
Posted on May 22, 2010
Testimonial: "Very detailed and organized. Very helpful."
StuartB
  • 807 Answers
SOURCE: connect midi to dell xps 420
You can use Midi to USB adapters.
Here: .MIDI Interfaces
Posted on Feb 06, 2012
Xps 420 fan
as long as it has the same connector than yes. fans are usually the same when it comes to personal computers
Mar 05, 2014 | Computers & Internet
Dell xps 420 noisy fan black screen
more than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
Jul 03, 2012 | Dell XPS 420 PC Desktop
DELL XPS 420 Fan noise, and goes into sleep mode
Maybe the fan is going bad. Open the case and check it to make sure it is tight by tightening the screws. Also make sure a cable or wire is not hitting the fan blades causing the noise.
Go into the Power Option in the Control Panel and set your Sleep or Hibernate options up higher or set them to NEVER.
Click Start/Control Panel or Start/Settings/Control Panel and look for Power Options.
May 23, 2012 | Dell XPS 420 PC Desktop
Connect midi to dell xps 420
Feb 06, 2012 | Dell XPS 420 PC Desktop
Blinking amber light xps 420
A Blinking Amber orYellow power button means that the power supply is receiving power from thesource but is unable to properly distribute it to the components. This can becaused by a defective power supply or a defective motherboard. Just to makesure that nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
Feb 17, 2011 | Dell XPS 420 PC Desktop
My Dell XPS 420 restarts itself whenever i play games on it
You might need a new Graphics card and a 400 w power supply. also, try cleaning it (the fans and HS's
May 13, 2010 | Dell XPS 420 DESKTOP - Intel?® CoreTM2...
Dell XPS 420 won't boot at all not even a BIOS screen
the bios is not starting ...
check the memory ram if its inserted correcly or
chek the beeps wen cpu starts and
http://kb.iu.edu/data/afzy.html
se if tha link is help full
Apr 29, 2010 | Dell XPS 420 PC Desktop
Jan 01, 2010 | Dell XPS 420 PC Desktop
Xps 420 keeps freezing or going to blue screen
Same with my Dell Vostro 420. At this rate I will just buy a new PC as I am wasting too much time on this. We tried usual stuff like cleaning inside, making cooler, removing certain virus software, still no luck. I have to restart 4 times a day and keep saving material. Can only restart by turning it off by pulling out power socket.
Jun 24, 2009 | Dell XPS 420 PC Desktop
Dell XPS 420  PC Desktop Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
