Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Need to know how and where to change the lamp?
How do you replace the lamp? where is it located at in this model?
  • 179 Answers
The lamp is behind the speaker cover, behind a little door in the front of the set. it is off to the left. you will need a philips head screw driver and a flat blade screw driver. don't force the new lamp in or you will push the connector behind it out
Posted on May 20, 2009
How do I locate and change the projection lamp in my rca TV,model d61130,high depth TV?
I know this sounds crazy but please go to youtube and type in 'how to replace my lamp in a RCA rear projection TV' and you will get multiple video's showing how to do this.
Nov 09, 2014 | RCA D61W20 61" Rear Projection Television
The `power botton flashes and the screen remains dark
The model number/brand indicated here (if wrong let me know) is a DLP set---means it uses a lamp---lamp is suspect number one.
Lamp is customer replaceable and easy to change--if you locate it and remove it-(it has a screw or two and a handle--cartridge with lamp pulls out) it is a good idea also to look at the color wheel -the lamp faces the wheel--if wheel is shattered or missing pieces it is the problem.
You are when pull lamp out looking to see if it is shattered inside--do not touch face of lamp with your hand and of course have set off and unplugged when you do this.
If the lamp--Google the model number with "lamp" and you will find dozens of sellers.
If the wheel is bad--do same to locate and You Tube has video instructions for replacing it---average people can do the repair themselves.
color wheel
4_25_2012_2_52_05_pm.jpgTypical lamp cartridge (not yours but similar)
SD TECH
Apr 25, 2012 | Samsung HLP4674W 46" Rear Projection HDTV
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
I would like to know how to replace the lamp
Drop the model of the projector and i would send you information on how to change the lamp. Changing the lamp varies from model to model
Jan 15, 2011 | Hitachi Televison & Video
Lamp needs to bereplaced,,,,, tv jvc model 61z886, need to know model of lamp i need and where to buy it
Google "DLP lamp" and you'll get many places from which to order lamps. Go to one of these sites and they should have a search box. Enter your model number and it should give you the part number of your lamp. Try several sites if the first one doesn't give you what you need to know. Once you have your lamp number you can shop the various sites for the best price. Note: You can buy your lamp complete (with the housing it comes in),..... or just the bulb and replace the bad one in the housing (cheaper)..... if you have the skills needed. If not buy it complete with housing. If you change the bulb only,.. don't touch it with your bare hands. Most bulb only packages come with rubber gloves.
Aug 24, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
My lamp light is on. can i change it myself ?
Hi your part number is TYLA1001 found it here : http://lamps-dlp.com/ProductDetail.asp?PartNumber=TY-LA1001&A=G&B=LA1001 It should be around the back.
Oct 01, 2009 | Televison & Video
A warning pops up on the screen of my Panasonic PT50LC13 That my lamp needs replacing and I need to reset the lamp timer, how do I reset the lamp timer?
After replacement of lamp, turn on TV, press and hold Volume Down button on TV front and press and hold Split/ Play button on TV remote at same time for 6 seconds.
That will reset lamp timer and confirmation display will come at TV screen.
Above info are also available in original Panasonic replacement Lamp box.
Aug 19, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Ware is the bulb located in the 50inch magnavox
  • hello here is what you need to know .on the location of your lamp & the right way to replace it. first thing is to, Turn off and unplug the unit before you replace the lamp.
  • Take care that no screws or other metal objects fall into the display interior. Such items could cause fire or electrical shock.
  • Do not remove the lamp except to replace it. Careless handling can cause injury or fire.
  • Do not replace the lamp immediately after the display is turned off. The high temperature of the lamp could cause serious burns. Allow the lamp to cool down at least two hours after turning off the display. display. 051021165929_314.gifthank you for useing fixya.com .
Jul 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Replacment lamp???
Casio YL-42 (210W) is the replacement lamp for your projector. It is available for around US 400.
Try and google to find the nearest place where you could pick up the lamp.
Enjoy
Feb 26, 2009 | Casio Office Equipment & Supplies
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
