Question about Samsung PCL545R 54" Rear Projection Television
HOOKING UP DVD PLAYER - Samsung PCL545R 54" Rear Projection Television
I need a code for hooking up a polaroid dvd player
You need the right tv remote code. Try to ger the code here
polaroid tv codes
May 25, 2010 | Symphonic ST420FF 20" TV
Would hooking up a dvd player,a vcr and a converter box cause the tv to smoke?
The short answer is simply no. If your TV made smoke, it probably has or will quit working, but it was not caused by hooking up a DVD player, a VCR and a converter box.
Nov 24, 2009 | Zenith B27A11Z 27" TV
Hooking up this dvd player -- I have audio but no
TRY USING THE RED AS THE YELLOW AND THE YELLOW AS RED, THIS SHOULD MAKE ONE SIDE OF THE AUDIO NOT WORK AND THE VIDEO WORK. REPEAT WITH THE YELLOW/ WHITE. TRY DIFFERENT CORDS. TRY IT ON A DIFFERENT SYSTEM. YOU MAY HAVE KNOCKED SOMETHING LOOSE INSIDE IT.
Nov 16, 2009 | Pioneer DV-343 DVD Player
Hooking up my DVD player to my TV and get sound but no video!
dvd player yellow output into
tv yellow input
dvd player white output into
tv white input
dvd player red output into
tv red input
if still no pic replace cords
Dec 31, 2008 | Televison & Video
DVD Player not working
Go to menu. Select inputs. Assign input 1(or whatever input you connectedthe dvd to) as DVD. Then exit menu. Press the input key, scroll over to DVD. I reccomend using a component cable with a digital audio cable, if you do not have a DVD player that has an HDMI connection. You will find that a blu-ray player will be much more satisfying for the television you have. Basically by hooking up that old dvd player to that tv, is the same as hooking an 8-track to a $2,000.00 stereo. It will work, but the quality is going to suffer! Good luck, and believe me. It is worth the extra money to get a blu-ray player. It will play all your old dvd's and blu-rays. That way you are getting the full potential of your set.
Dec 22, 2008 | Mitsubishi WD-60735 Projection Television
Hooking dvd player up to tv
Sounds to me as if you have not set the Playback CODEC properly.. In the Menu system, as in NTSC or PAL. Make sure that the DVD & Player are set the same Format ie: NTSC or PAL..
Nov 30, 2008 | Emerson EWF2004 20" TV
Hooking up dvd and satallite
omg im having the same exact problem!! i hate it only im trying to do this with a durabrand DVD player
Oct 30, 2007 | Emerson EWF2004 20" TV
Hooking up DVD player to HD wires.
Have you tried to go to a different channel?
Apr 16, 2007 | JVC XV-LTR1 DVD Player
Samsung PCL545R 54" Rear Projection Television Logo
14 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
