Question about Avanti Compact Thermoelectric Refrigerator
Avanti 248yw protable refer wont get cold
My avanti 248yw refer will not get cold any morethe compressor goes on & off every 35-50 sec. i tested the stat it stays closed when the comp goes off. i checked the comp for continuity all looks ok no grounds. i checked the olp switch continuity looks ok (0 ohms) the ptc starter switch i think may be the problem i get about (1200 ohms) on it could this be the problem? i don't want to replace it,if it's not. or is there something ealse that i missed. thanks sac
  • 2 more comments
  • lokospice Jun 27, 2009
    Well i waited as long as i could. i chanced buying the ptc starter switch and guess what that was the problem. i changed it and it works. i know not all problems would work out this way but i took a chance. i also had a hard time finding the switch. i found it on (RepairClinic.Com) for about $28.00. hope this might help someone else. i don't know how long it'll last but i'm going to enjoy it while i can. thanks sac
  • lokospice Oct 21, 2009
    The replacement part# for the starter switch is
    (P6R8MC)this is not the same# on the part itself and
    the model# didn't help. i used the original# that
    was on the part.and it worked (I got lucky)
    Hope This Helps
    Lokospice
  • soultraindar May 11, 2010
    Thanks!! I appreciate it.
    Locospice,
    What is the part number of the replacement Starter Switch? RepairClinic doesn't have anything listed under the Avanti model #248YW.
    Thank you!
SOURCE: Avanti EC15W-2 Thermoelectric - stopped cooling
I think the circuit board is nothing more than a power supply converting the 120 volts ac to dc. If that goes then there is no way for the solid state device to cool,
Is there dust under the back cover? Is there frost/ice build up in the fridge fan compartment. I suggest to unplug for a day and try again. Hope this helps.
Posted on Feb 29, 2008
SOURCE: avanti water cooler
it freezes up
Posted on Aug 28, 2008
SOURCE: Avanti Compact Refrigerator Mod.#18ERC/RW
I am about to purchase one of these--Have you found a solution yet??
Posted on Oct 06, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
  • 340 Answers
SOURCE: Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Posted on Jun 17, 2009
My Avanti model RM4400W WILL NOT GET COLD CAN HERE IT RUNNING BUT NOYHING.?
If you can hear the compressor running in the back you have one of a few problems. A refrigerant leak, restriction or a failed compressor. All of which requires sealed system work
Aug 25, 2016 | Avanti Refrigerators
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Nataly if there is not any cold air anywhere and compressor is running that indicates a Freon leak and worth very little due to repair cost. You must be sure that compressor is running not the fan noise
Appliance 911 Sea Breeze
Nov 12, 2015 | Avanti Refrigerators
I have a compact avanti regrigerator. It doesnt get cold anymore. What do you think might be the problem? I bought it since 2007.
There are three possible reasons for this;
\the thermostat needs replacing
\The refrigerant has leaked out
\ the compressor has failed
Either way you will need a technician to look at this as it involves an electrical diagnosis
Apr 05, 2011 | Avanti 308YWT Compact Refrigerator
I have a Avanti wc492d wine cooler that is not working. The unit shows power(lights are working) but it will not cool at all. I can here a click sound when I change the temp set, but the cooler will not...
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti WC492D Wine Cooler
Temperature began to warm up daily until now it just stopped cooling
Hi, I tried to cross the model number you gave with Avanti and it did not do an exact cross reference.
Usually when a cooler slowly warms up the causes can be
1. The Compressor is not running at full speed or has stopped running
2. The PTC start / run relay / Klixon assy mounted on the Compressor has failed
3. The run capacitor has failed.
4. The temperature control has failed.
If the compressor is running and it is NOT cooling then there is a coolant leak or the coolant system had become blocked usually in the capillary tube area.
The current model numbers for parts are here:
http://www.avantiproducts.com/parts-accessories/current/yes
And the Discontinued model parts are here:
Just note there are many aftermarket (like part) sources that will be much cheaper than Avanti sourced replacement parts. Most repair techs would advise you to use locally sourced replacement parts.
Feb 04, 2010 | Avanti WC42 Wine Cooler
My Avanti is not getting cold.
I have an Avanti mini refrig. thermoelectric having trouble getting it to cool or cold it is a model EC15W-2
Jan 06, 2010 | Avanti EC15W-2 Compact Refrigerator
Frig not working
feel compressor to see if its hot may have leak in system call avanti they love their customers for real i was authorized for them they wan you happy if the lights not cumming on check power
Dec 30, 2007 | Avanti 322Y Compact Refrigerator
Avanti Compact Thermoelectric Refrigerator Logo
158 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
