Question about Fossil FS3105 Wrist Watch
How do you set a Zunammy mens chrono watch? - Fossil FS3105 Wrist Watch
Adjusting hands to markers
What you need to do is to pull the crown to step 2 (full out) and then push the chrono top chrono button. Then the second hand will start moving one tick a time all through the dial. Keep pushing it until you reach to zero. then push crown back in,, That's it.
Feb 18, 2014 | Swiss Army Maverick GS Chrono Mens Watch...
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
I cant get the start position of the chrono on my lancaster watch to 0,. it starts at 45 secs.
pull the crown out to second position then press start button till it goes to 0 then push crown back in..........
Oct 11, 2013 | Lancaster Designer Mens Watches, Top Up...
I need to reset the chrono to the center point.. how do i do that?
mcdevito75 here, generally you"d press the chrono button to start the chrono and press again to stop it, NOW! press the chrono button again to re-set it. Should work.
Feb 11, 2011 | Cerruti # CT61191X403011 Watch for Men
I bought a ARMANI CHRONO WATCH - AR0294
Big hand is for chronometer function, not for counting seconds. The small seconds hand is for continuous seconds counting and should tick all the time.
Mar 24, 2010 | Giorgio Armani Emporio Armani AR0527 Watch...
I Have A Fossil CH2446 Chrongraph Avenger With No Manual
Just pull out the time setting knob to the position 2(ie between outermost & innermost position).Now press the chrono button A(the upper one)repeatedly till the chrono needle is on 12:00 poition.Now you can press back the time setting knob to initial position.
Hope that helps you!!
Mar 11, 2009 | Fossil Metal Chronograph Avenger CH2446...
Problem with the large chrono indicator
Pull out the crown to the #2 position then push the start /stop button to move the second hand up to zero
Dec 09, 2006 | Skagen Men's - PERFORMANCE TITANIUM CHRONO...
Fossil FS3105 Wrist Watch Logo
35 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
