Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
My shark rotator NV501 has lost suction and no longer will pick up when I vacumn.
My Shark rotator NV501 has lost suction and will not pick up dirt when turned on.
5 Suggested Answers
SOURCE: shark steam mop model 3101
Here is the webite to purchase the carpet attachment for your steam mop.
http://www.fixya.com/support/t704954-shark_steam_mop_model_3101
Before you buy the carpet attachment, you might want to read this review. I found it very helpful because I couldn't find much on how it works on your carpet or any reviews on the attachment. Her comments were all positive.
here is the link:
http://www.epinions.com/content_425654455940
Posted on Sep 17, 2008
  • 134 Answers
SOURCE: Infinity Shark Vacuum
YOU HAVE BROKEN THE BELT, ORDER ONE FROM HERE
http://www.sharkvac.com/partsearch.aspx?CatID=cxmdqvOilfw%3d
Posted on Feb 14, 2009
satch498
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
heatman101
  • 43501 Answers
SOURCE: shark steam mop does not create steam. 7 mos old
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
a
Posted on Sep 26, 2010
Y Shark "Professional" model 540 26 is making a terribly loud noise and not picking up dirt. t also gets HOT
Check( 'beater bar',suction tube to canister) for accumulation of hair,carpet fiber,pet hair,etc....cut hair,etc,with scissors,clean...might also be hair stuck in belt that drives beater bar
May 08, 2017 | Shark Vacuums
My Shark Navigator does not have any suction. The roller brush works. What should I do?
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it.
If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum.
If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
ou can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+navigator
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 18, 2016 | Shark Vacuums
Shark navigator lift away turns on but no suction
It seems that there may be something blocking the airway. To fix this, please make sure to unplugged the unit from the power before performing this.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, keep reading for other options to fix the suction.
If both your foam filter and felt filter have not been cleaned in the past month, this may be why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
If none of the other solutions worked, your motor may be bad. You would need to check with Shark about this.
If your need to replace your Shark parts such as filter, belts or hose, you can also order replacement parts directly to us. You can check our online store in this link: http://www.thinkcrucial.com/search?type=product&q=shark
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Oct 17, 2016 | Shark Vacuums
Shark rotator no suction
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+rotator
Ava B.
Oct 10, 2016 | Shark Vacuums
Shark NV350NZ NEED 2Filters 1 foam 1 falt and pipe on rotating head were I get them and price please
Shark Vacuum Parts & Accessories ' eBay
www.ebay.com/sch/Shark-Vacuum-Parts-Accessories/42146/bn_7722312/i.html
  1. Cached
Shark Professional Rotator Lift Away UV560 Floor Nozzle Part NV501 HEAD ... Shark NV400 Rotator Rocket Vacuum Cleaner Motorized Floor Nozzle lower ...
You can obtain parts from the above. Quote model number.
May 24, 2016 | Shark Vacuums
How do I get to the belt that runs the roller brush to my Nv501 31 shark
sometimes there is a hidden one under a sticker or behind the belt
Dec 11, 2014 | Shark Vacuums
Why won't shark cordless stick vac motorized brush work?
Is the brush rotating, if not the belt is broken or jammed, if so remove the bottom plate and all will be reveiled.
Oct 17, 2014 | Euro-Pro Shark Cordless Stick Vacuum...
Chess piece lost in shark navigator rotator
You must extract the chess piece or else it could move within the unit and cause further damage. If you cannot open the shark and get to the intake section, then have a service do it for you.
Feb 26, 2014 | Shark Helmet NV22L Shark Navigator Upright...
My Shark vacuum is losing suction. How do I fix that?
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
You can purchase a wide variety of high quality Shark replacement parts for your Shark Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Dec 09, 2011 | Shark Navigator Bagless Upright Vacuum
My vacuum (shark modle #UV210BV) turns on but has absolutely no suction.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Jul 08, 2009 | Euro-Pro Shark Professional Upright Vacuum...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
170 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
