Question about Dell Dimension 3000 PC Desktop
Does the dell dimension 3000 have a dvd burner?
  • fougzki May 11, 2010
    From their site it seems it doesn't have a dvd burner only reader. Why use combo drive if you can provide a dvd burner.
    One thing is to test it. If it can recognize a dvd media if you try to burn a dvd.
  • Dick
    Dick May 11, 2010
    All Dell systems are customized and built to order. Some Dimension 3000 systems had a dvd burner, some did not.
    President:
  • 2,666 Answers
No it comes with a CD/RW.
Posted on May 18, 2009
  • 5 Answers
SOURCE: lost password for Dell Dimension 3000.
If you have all of your important documents on a separate hard drive then you can reset the computer main frame and then you can recreate a new password! and if that doesn't work then you can always have a computer tech. take a look at it! Infact i'll give you the number to a guy who live's in S.C. His name is Dwight Welsh but you can just call him mister Welsh. So any ways his cellphone number is (910) 494-7467.
Posted on Sep 14, 2008
gotgeek2
  • 565 Answers
SOURCE: forgot my password to my dell dimension 3000, how can I reset?
It's a large file, but you can download and burn a copy of:
http://www.ubcd4win.com/
It's a bootable cd that has a password recovery tool plus a lot of other stuff.
Posted on Feb 13, 2009
  • 13 Answers
SOURCE: Clear cmos Dell dimension 3000. It don't have pin or jumper
Open the case and locate the CMOS battery. Just nest to it should be a button or jumper. Press the button or remove the jumper, then start the machine.
If it's a jumper, turn the machine off once more and replace the jumper before continuing.
Posted on Apr 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: Dell Dimension 3000 CD/DVD drives not working
You can download the drivers from dell website, download.com, and many other sites. Download, then double click on them to install them. Once installed, reset pc.
Posted on Sep 13, 2009
  • 14 Answers
SOURCE: forgotten pasword for dell dimension 3000
If you want the quickest way, then I think you can take a try this password recovery software, a program which helps to reset Windows Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. Your DELL Dimemsion is supported. Good luck!
Posted on Nov 17, 2011
What do I set my CD-Rom Jumpers to in a Dimension 1100
Which is it a Dell 3000 or Dell 1100 ?
The jumper settings on the rear of the DVD drive; set the jumpers to "cable select" mode (if you are uncertain how to set the jumpers, check the documentation that came with your drive or look for a diagram printed on the drive itself). Insert your DVD drive into the selected drive bay and connect the IDE and power cables. Use the screws that came packaged with the drive to secure the component to the drive bay.
Dell Dimension 3000 Service Manual
http://support.dell.com/support/edocs/systems/dim3000/en/SM/sm.EXE Dell Dimension 3000 Users Guide http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
ASUS 22x Internal CD/DVD Burner not working
Look into the little jumpers on the back.
If its SATA its np But if its IDE you need to set the jumper to master or slave or cable sellect.
May 01, 2012 | ASUS 22x Internal CDDVD Drive Burner
Cd dvd burner on dimension 3000 desk top with xp light wont come on or tray wont open
sounds like the drive may have failed
Reseat the power cable to the drive
if no change, replace the drive
Jan 22, 2011 | Dell Dimension 2400 PC Desktop
What dvd burner will work with my dell dimension 4700
There shouldn't be any issue with grabbing a random DVD Burner and popping it into your machine. As long as the DVD Burning software is compatible with the current Operating System, and as long as you have the approprite driver software (which usually comes with the DVD burner these days)
Apr 24, 2010 | Dell Dimension 4700 PC Desktop
DVD drive Read problem in my Dell Dimension 3000
Make sure you have any and all Windows 7 updates from Microsoft, along with any updates for your DVD drive for use with Windows 7. Some components work fine using Vista SP2 drivers, but some will need an update to work with Windows 7.
This Microsoft site might help verify if your DVD drive is compatible with Windows 7:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Feb 12, 2010 | Dell Dimension 3000 PC Desktop
How do u work a dvd burner on a dell desktop
Here ya go
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=DAA1819A3EA92315E030A68F2728608A&doclang=en&cs=
Jan 24, 2010 | Dell Dimension 3000 PC Desktop
Dell Dimension E510 DVD Burner
Try to use cd cleaner to clean the lens, if this doesnot work, this means your lens is died, change the DVD Rom.
Thanks for using Fixya
Oct 05, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
I had a dvd burner on my dell, then it crashed, not able to find it now I have a dimension 3000
It sounds like you could have a problem with the hardware driver for you computer. You can visit the site below and download the driver reset tool. On the site you will see a link with instructions on how to download and install the program. Once you've done this try rebooting your computer and see if you DVD burner now appears under my computer.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R92578&SystemID=DIM_CEL_3000&servicetag=&os=WW1&osl=en&deviceid=9309&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=25&fileid=120687
Jun 27, 2009 | Dell Dimension 3000 PC Desktop
Cd burner not recognized
Hai,
Please install nero Burning software. normaly it will come with a cd rom or dvd rom.Install the software and restart the system. After installation in start menu programs select nero express essentials and select which ever media u want to write cd or dvd.If u r not getting nero software try to donload cd burner xp from the following link and install it.Its a free software. http://cdburnerxp.se/
Thanks
Mar 21, 2009 | Dell Dimension 3000 PC Desktop
DVD player
The lens is dirty . You need to clean the lens . You can clean the lens by using lens cleaner disk .
Jan 30, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
628 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
