Question about Kenmore 65812
Refrigerator Running Warm
I have a 5 year old Kenmore refrigerator with a top freezer.  The refrigerator never ran really cold  and it recently has started to accumulate ice on the back wall of the freezer compartment.  The model number is 106.60184001.  It is something that can be fixed or should the refrigerator just be disposed of?
  • 473 Answers
It has a defrost problem.  3 things could be the problem.  1. Defrost thermostat  2. Defrost timer  3.  Defrost heater.  The timer is in the fridge section in the middle of the console behind the controls.  On that console you will see a little hole that will give you access to the timer gear that can be turned clockwise (slowly until it clicks) to put it into defrost.  Take the back panel off in the freezer.  Once you have put it into defrost see if the defrost heater comes on behind that panel in the freezer.  If it comes on then the timer is bad.  If the heater doesn't come on then it is most likely the defrost thermostat which clips onto the evaporator behind the freezer panel.  It's less likely, but it could be the defrost heater itself but it can easily be tested with an ohm meter for resistance.  Any resistance means it's ok.  Let me know if you need further assistance.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
Moved 9 year old kenmore to friends house just replaced ice maker. lights come on but refrigerator is not getting cold water is running ok but is warm
Is the freezer getting cold?
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My kenmore elite all fridge does not get really cold any more, only the fan seems to be running and maybe not the compressor, its only 2 years old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 10, 2011 | Kenmore Refrigerators
Kenmore refrigerator with top freezer purchased about 8 years ago. The freezer isn't freezing food thoroughly and now the refridgerator is not keeping the food cold enough. What could be the problem? ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Mar 05, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
I have a refrigerator that is about 12 years old. It was working fine, unntil about a week ago, everything got warm in the freezer and now the fridge part is cool. Any ideas on what could be wrong?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 04, 2010 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator is warm but bottom freezer works fine. It is a Kenmore with a bottom freezer and is about 10 years old
Listen to see if the fan motor is running, without the fan the air cannot circulate to the top refrigerator. If it is running then look for the baffle assy and see why its not opening. The baffle is a small door that opens and closes to keep the air going to the refrigerator from getting to cold. Basically its how the thermostat regultes the temperature in the refrigerator. Opening the baffle when it needs cold air and closing it when its cold enough. Finally check the back wall of the freezer and see if there is frost all over the back wall. If there is frost all over the back wall you are dealing with a defrost issue. Hope this helps
Jan 24, 2010 | Refrigerators
Refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Oct 13, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Kenmore 65092 Refrigerator
This fan will be running anytime the compressor is running. If it isn't then it has failed and will need to be replaced.
Nov 12, 2007 | Kenmore 72912 / 72914 / 72919 Bottom...
Kenmore 65812 Logo
178 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
