Question about Toys
Disney plane after 1 week the propeller doesn't go around when the button is pushed
2 Suggested Answers
stonephoenix
  • 563 Answers
SOURCE: no power
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV needs repair. The problem is there are no longer parts available to repair Disney TVs. The company that manufactured that model is no longer in business. No other company has come along to pick up where they left off, so unfortunately there is no way to repair a defective Disney TV.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 02, 2009
When you increase throttle and engine rpms what happens?
If you are flying level you climb. If it's a propeller plane and you don't add rudder to counter "P factor" you may also turn a bit.
Jan 04, 2017 | Aircrafts
How do you replace the propeller on the Air Hogs Sky Stunt, Blue?
To replace the Propeller on an Air Hogs Sky Stunt plane (I got this from their customer server number):
1.) Hold the propeller and turn the nose (at the grey plastic edge, not the rubber) counter clockwise (aka left) until the nose unscrews.
2.) Slid off the OLD propeller.
3.) Slid on the NEW propeller (You will notice there are slots on the propeller mount), need to line up the propeller with those slots.
4.) While holding NEW propeller, screw the nose back on (similar to step # 1) clockwise (aka right).
Hope this helps someone else.
Mar 15, 2013 | Toys
What kind of engine is used in airplanes?
The type of engine that airplanes use is the turbine gas engine, or jet engines. They have been in use since World War 2.
Aug 29, 2012 | Champion Sport & Outdoor - Others
I assembled my new Super Cub RC plane and when I put the battery in the plane the elevstor snd rudder would move, but when I pushed the throttle up it didnt work. I am new to this and troubleshot it many...
G o back to your manual. I had this problem also. The procedure must be followed properly. First, make certain your throttle is in the off/down position. Second, turn on transmitter. Third connect battery. Once you place the battery in the enclosure and lock the cover you should be working properly. Last but not least, when finished flying, remove the battery BEFORE powering off your transmitter. You must follow these steps. You can NOT leave the battery in the plane when not in use.
Jul 21, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Water won't get hot, code c2 11
1-866-720-2076
Available between 7AM - 7PM Central Time
7 days a week
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
No power
Jul 02, 2009 | Disney 13" TV
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Disney princess 13" tb p1300 ntv
disney will replace for around 30 dollars. Google disney customer service and get number is you are interested.
Apr 07, 2008 | Disney 13" TV
Toys Logo
73 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
