PC Desktops
Problem for PC Desktops
Generic problem for all PC Desktops
Light is solid yellow on front switch, won...
By bleeper87 on Oct 17, 2007
the computer is dying.  I thought it was the power supply.  I got a new one. Now...when I go to start the computer up, it will not start
Comments:
Oct 17, 2007
- thanks for the information.  I've got about 10 like this here at the school I work at.  I'll have to price new boards.
Same Problem
Apr 29, 2009
-   The machine was showing some hard drive problems, it blue screened once in a while. S.M.A.R.T. checkup showed the hardrive had problems. So swapped Hard Drives, i re-installed windows vista premium after 10 mins the machine shut down and it would not boot. Solid yellow power light, no beeps. -   Selphid
Jan 01, 2009
-   help! i have a dell Optiplex gx270 and like i get it to work sometimes when i leave it on it works perfectly! but when i turn it off and leave it off it wont start back up.
on the switch board theirs a yellowish red light (amber?) and on the power button its blinking rapidly amber.
is my psu bad? or is my comp dying. and i read that you can just try the psu on another comp, but would any comp work? and i don't have a tester or w/e.
PLEASE HELP ME! FALLOUT 3 IS CALLING MY NAME!!!!!!!!!!
-   Scubaaaaaa
Dec 31, 2008
-   has any of u figured out how to( fix a e-machines ) light stays on mother bourd but will not boot up
-   Guest
Oct 12, 2008
-   I have the same problem accept that it is making a high pitched continuous rapid beep noise kind of like if you accidently place something on the keyboard when it is on. (Not sure how else to describe it). I have tried every suggestion I have found to no avail. HP of course wants big bucks to even check it out. If I had the extra bucks I'd get a new one. Any one have any ideas or suggestions, I would really appreciate it.
Distressed-   debsnight
Jun 27, 2008
-   yellow solid light on front switch and computer will not boot up and monitor is black
-   Guest
Best Solution
posted on Oct 17, 2007
Helpful)
normdoty
Rank: Master
Rating: 84%, 28 votes
if you are certain the power supply is good(try it in another machine) and its completely connected it sounds as if your motherboard is going bad, there is a 5-volt supply in your power supply that does not turn off when the system shuts down, its called 5-volt standby, this runs some small circuits on the motherboard that monitor the power switch, when its pressed the circuit starts up the whole power supply. thats how we can power off the system with software. usually its a custom chip and some components, but without the schematics of the motherboard and the replacement parts and the ability to de-solder and solder on a multi layer board its not usually repairable by the end user.
the system memory and processor are not even used in this part of the system startup, they come into play after the supply is up and stable and supplies the power good line to the motherboard.
make sure the supply is good, and all connections are making contact, that none of the pins have backed out of their housings when being plugged in and that there are no cracks in the solder joints where the power connectors attach to the motherboard.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
What is the best NAS for about $300 (+, - $100)? I was looking at... (More)
Answer
sx2800 how is it compared to other brands its size
Answer
How do I save a Publisher document into a WORD document
Answer
my e2100 is blingking i flash it bat flashing ok bat no power
8 Other Users Have The Same Problem - Continued
Comment by erickyn, posted on Jan 26, 2008
I thought it was the power supply. Now...when I go to start the computer up, it will not start.
Comment by ExplosiveRed, posted on Dec 21, 2007
One day after I shut down the machine, it just refused to start back up. When I hit the power button, there is a yellow light there, but nothing at all boots up.
When I connect the power plug into the computer, a green light turns on, on the motherboard. That means the power supply is working. I took out the RAM and re-inserted it, and still no results. What could be wrong?
Comment by Guest, posted on Dec 21, 2007
Exact same problem. One day after I shut down the machine, it just refused to start back up. When I hit the power button, there is a yellow light there, but nothing at all boots up.
Perhaps the mechanical connections in the power switch is faulty. If so, how would I correct that?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repairmen
in San Mateo, CA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
