Question about Hotpoint 18.2 cu. ft. Top Freezer No-Frost Refrigerator CTX18DABWW
Refrigerator is too cold even on highest temperature setting
Rf220 not cold enough at highest setting
Is the other freezer setting set differently? u cannot have both settings set to high ans they will conflict with one another. u may have an issue with ur cold control thermostat, can check it with a multi meter. may also have a low freon issue. is freezer fan working ok? door seals ok?
Oct 12, 2014 | Samsung RF220NCTASR 21.6 Cu. Ft....
Freezer and refrigerator are not very cold
if it is a cheap refrigerator the compressor may not be able to handle keeping both areas cold at the same time... try turning down the fridge temperature to see if the freezer then gets colder.
Jul 26, 2012 | Whirlpool Refrigerators
My refrigerator is not getting cold even though I have changed the temperature setting to the highest value. The freezer is working fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 11, 2010 | GE GSH25JFR Side by Side Refrigerator
Freezer too cold even at highest setting.
http://downloadcenter.samsung.com/content/UM/200802/20080205162030328_DA68-01632A_EN_V0.3.pdf
bad temperature sensor?
i suggest posing your inquiry direct to Samsung Support Staff
800-SAMSUNG (800-726-7864)
www.samsung.com
Samsung Electronics America, Inc.
400 Valley Road Suite 201
Mt. Arlington, NJ 07956
Mar 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
Refridgator too cold and on highest setting
i'm guessing your fridge is over - packed with alot of food - i found if i made more space - temperature returned to normal cooling.
hope this helps
marneypants
Oct 02, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
The freezer temperature is too high. is it controlled somehow? the fresh food compartment is a bit warm too - though the setting is on coldest.
I've made a mistake before with thinking that I was setting the adjustment correctly on a refrigerator before, sometimes those dials are hard to read if there is a graphic scale, or symbols etc. Instead of numbers with the highest number being the coldest setting. Anyway make sure the temp setting is set correctly, these are found in the refrigerator side.(yes even for the freezer, so it does'nt freeze up) I adjust mine all of the time, things only need to be so cold right.(helps my elect bill) Make sure those special compartments have clear air passages to them. best regards.
Jun 08, 2009 | Haier HRF10 Top Freezer Refrigerator
Won't get up to temperature
defrost timer broke, needs to be replaced
Apr 02, 2009 | Maytag MTB2191AR Top Freezer Refrigerator
FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 30, 2008 | KitchenAid KSRG25FK Side by Side...
Refrigerators Logo
19 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
