Question about Magnavox DV225MG9 DVD Player VCR
Reset button distorted tape picture
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
Clean the head
I have a DCR-100, which is basically the same camera, and had the same problem after I hadn't used it for about 5 years. After running a cleaning tape through it four times it became much clearer, but sometimes, reviewing my equally old tapes the pixellation/distortion reappeared spasmodically. I ran the tape at FF to the end, and then back again. Seemed to fix it. I think after a long period of disuse the recording heads oxidise and it takes quite a bit to clean them. As to why loosening up the tape works - no idea!
Aug 16, 2014 | Sony Handycam DCR-PC9E Mini DV Digital...
Picture during playback is badly distorted
There could be several reasons for badly distorted pictures. considering the age of the unit as DV camcoder which I am guessing would be quite a bit. Most likely the heads have worn out and need replacement. I am assuming you have this problem with newly recorded tapes being played on a TV directly from the camcorder. For this you may also need to check if you are using new tapes and whether the recording mode is PAL or NTSC as per the TV format.
Alternate test would be to play back a previously recorded tape back from the camcorder. That way at least you can establish if the problem is the read head or the write head or the tape itself.
Aug 16, 2014 | Canon Elura 100 Mini DV Digital Camcorder
I think it's the av channel but not sure
Make a reset to this set. Refer its user manual for details about how to do this.
Jun 03, 2012 | Symphonic WV806 DVD Player/VCR
Wrong setting picture distorted is there a reset button
Hello
There is no reset button to this DVD changer. To reset it to its factory settings, just unplug it from the power socket, and plug it again after 10 minutes or so. This will reset the internal memory of the set. OK.
Dec 07, 2011 | Yamaha DV-C6660 Multi-disc DVD Player
The vcr picture is very distorted. I know that
I’ve never had much luck with tape cleaners. I found that you can use acetone. You can buy it in any hardware or k-mart,walmart. Open the VCR up and find the big chrome cylinder that spins. It has the heads on it. There little windows on the cylinder. Clean them with the acetone. Use just enough acetone to wet the foam and rub the heads lightly. There is sometimes 2 to 4 heads on the cylinder. Let dry for about 5 to 10 min’s then play a tape. If still not a good picture, clean again. Sometimes if takes more than one cleaning. Hope this is helpful.
Oct 30, 2009 | Televison & Video
Why is my picture distorted? From the start up it is distorted. Even if nothing is in it.
make sure all connectors are secure for starters second id try different cables
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
After recording a program using the Toshiba W522, the picture rolls and jumps up and down, while in playback mode. I have no problem with recording, its just when its time to actually watch the program,...
If the tapes are old or cheap, they may simply be no good. However, I found that the automatic tracking is the best thing to ensure perfect quality picture and sound.
Jun 22, 2009 | Toshiba W522 VHS VCR
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Magnavox DV225MG9 DVD Player VCR Logo
54 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
