Question about Sony Handycam CCD-TRV68 Camcorder
Cant see subject in viewer or lcd display when in camera mode
All functions seem to work on camcorder, but cant see anything in eye viewer or lcd display.
  • 473 Answers
SOURCE: Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Posted on Sep 14, 2005
Arpi
  • 326 Answers
SOURCE: LCD is not working
Hello, in order to repair this Camcorder you should replace the LCD panel flexible cable FP-185 and the plastic hinge cover. If you need more info please advice. Best regards. Arpi
Posted on Apr 26, 2007
  • 169 Answers
SOURCE: No display in viewfinder and LCD
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
Posted on Aug 11, 2007
  • 169 Answers
SOURCE: Black Display Screen
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Posted on Nov 05, 2007
SOURCE: sony CamCorder Model DCR-HC42E . (lcd showing blank)
i have the same proble , pls any sugestions?
Posted on May 09, 2008
I CANT VIEW IN THE VIEWER WHEN IN THE CAMERA MODE. IT WORKS FINE IN THE VIDEO MODE.IT WILL TAKE PICS IN THE CAM MODE BUT NO SCREEN.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 23, 2010 | Canon PowerShot SD600 Digital Camera
My dsr pd170 lcd view screen is viewing in negative imaging. it seems to be filming fine, but the image quality slowly degrades while filming. Since we work at a camp and film things like talent shows...
dear
first tell me when u close the lcd pannel , then is the view finder working fine , if not then
view finder cable is broken . u cant fix it your self as u need to open the camcorder .you must not be having the proper tools for that.
and regarding the lcd part , if the display is fine for a while ..and then
while using it it goes fade , shows grey colour or lines in it . then its lcd problem ...ur lcd need to be replaced .
Jul 25, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Viewer turns off (black) when folded back against the camera.
When the big LCD is black the view finder will turn on, right?
You need to replace a new hinge unit. Here is similar solution
How to fix an intermittent display LCD on Canon PowerShot S5IS
Jun 26, 2009 | Canon PowerShot S2 IS Digital Camera
Minolta dynax 5 camera, diplay has disappeared
does this model have the eye viewer also? if so check and make sure the switch is toggled to displayed and not for the eye viewer. look into the eye viewer and you should see your display. it is simple switch to toggle it to the display mode.
Apr 10, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
SONY DCR-SR300 with CMOS viewfinder
I suddenly had similar problems with my SR300. I replaced the flat ribbon cable (looks orange) between the body and the LCD display and camera works like new. The ribbon cable is subject to cracking the internal wires where it flexes when you open and close the LCD display. There was also a new part number for the cable so I suspect it is a known problem.
Sep 02, 2008 | Sony Handycam DCR-SR300 Camcorder
No Image Through Viewer
So your camcorder has problem of No Image in Viewer. Will you let me know this problem is in Camera mode or in playback mode? and this camcorder has 2 viewer, one is LCD and 2nd is Eyepiece. Which one is not showing image?
Jun 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Lcd viewer is not functioning
Hello, in this case there is a broken flat cable called FP-185 pn:186476111. You should also replace the cover pn: 218843302. Best option for you is to contact the nearest Authorized Sony Service. If you need more info please advice
Mar 10, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Canon gl1 - no picture in the fold out lens
By placing the POWER switch into CAMERA mode, you will then be able to press the MENU button, and access all camera adjustments....including the LCD function.
Mar 05, 2007 | Canon GL1 Mini DV Digital Camcorder
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Handycam CCD-TRV68 Camcorder Logo
26 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
