Question about One For All URC-6131 Remote Control
I lost my code for my sanyo t.v. and my fisher vcr
Re: I lost my code for my sanyo t.v. and my fisher vcr
Dont know if it will work but is'nt it the same code you would find in "sky digital codes"
Posted on Oct 17, 2007
0 characters
3 Points
Need sanyo universal remote code to add a ge vcr
This remote control have no setup codes for GE VCR.
Oct 26, 2012 | Remote Controls
Check this code combination: [ [0416 0267] ]
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR/DVD. Otherwise just the one code operates both the TV and the VCR/DVD
Oct 01, 2012 | Remote Controls
How can I get the 3-digit device code for a Sanyo TV Set? I lost the list!!
Three digit universal remote code for Sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote codes for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Feb 20, 2011 | Universal Remote Control Remote Control
I recently purchased a "TDE SYSTEMS" jumbo
sanyo tv codes are 0506,0311,0612,0002,0428,0802,0412,0619 and emerson vcr are0626,0126,0826,0227,0327,0630,0632,0134,0037,0625,0924,0324,0128,0228,0428,0528,0447,0247,0724,0325,0526,0726,0027,0527,0827,0927,0628,0530,0830,0731,0634,0735
Dec 13, 2010 | Remote Controls
Hi, Take a look at this link, I hope it helps you, if not let me know.
Regards - Anthony
Feb 08, 2010 | Emerson Remote Controls
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
Sanyo TV with no remote but have a fisher remote, how can I set u
you can try this,
sanyo tv codes 025,023,054.
fisher tv 025.
Apr 09, 2009 | Remote Controls
Need a code for sanyo vcr that will work with a remote control
Need a code for a sanyo TV from a innovage jumbo universal remote. Thank You
Jun 27, 2008 | Directed 434MHZ Remote Control
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
One For All URC-6131 Remote Control Logo
67 people viewed this question
Top One For All Remote Controls Experts
Are you an One For All Remote Control Expert? Answer questions, earn points and help others
