Question about Garden
Need to Change the oil
A friend recently gave me a 10 yr.old Yardman Lawn Tractor.I have it tuned and running,but I cannot locate the oil drain plug and filter. Can you tell me where it is and what oil is recommended. It is a twin engine with a 42 " deck.
    Sniper:
  • 57 Answers
On most likely the right side of the engine is where you will find the oil drain. It will likely be in the form of a pipe with a cap. On most of these models the will not be an oil filter. Briggs and Stratton recommends SAE 30 engine oil. Also log on to mtdproducts.com and you should be able to download an operators manual. The model and serial # are located under the seat.
Posted on May 18, 2009
Where is the oil drain plug located on model 407577
Should be a plug on right side engine almost bottom of engine.
Apr 22, 2016 | Yard Man Yardman Riding Lawn Mower 38in...
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
How to change the oil in my MTD 6.5h Honda yardman
Many mower engines no longer have a drain plug, or the plug is covered by the deck or other components, the best way is to suck the oil out via the oil filler, there are plenty of inexpensive vacume pumps availble that makes the job easy, check out the dealers or e bay.
Mar 14, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I need to know where the screw is to release the oil on the yardman 12a559k401 to change the oil unable to find manual on line
The drain plug will be located in the base plate of the engine at its lowest point. There may be more than one for ease of access, depending on the engine type and design of the mower. Drain oil when the engine is hot and tilt it so as to drain the maximum amount of oil. (Remove the spark plug lead before working on the machine).
May 15, 2011 | Mtd Garden
While performing an oil and filter change on my lawn tractor, what can I use to clean the sludge that may be in the oil system?
You could use new oil diluted with kerosene, or even gasoline, to help remove sludge....just run it for a short time and then drain it. But since you have a filter to remove bits of metal from the oil I think there is no need to do anything except change the oil at recommended intervals. It would be helpful to buy a magnetic drain plug to trap small pieces of metal.
Dec 05, 2010 | Toro LX423 20HP Lawn Tractor 13AX90RS848
Oil change instructions and oil recommendation (lost manual)
Hello, oil to use in the engine depends on engine if it is a Kohler you will want to use 10w30 approx 2qts. The Briggs & Stratton engines use HD30 or SAE30 approx 1.5qts. Use the dip stick to ensure you have the right amount and don't over fill.
To change the oil:
  • run engine about 10 minutes to warm up oil so it flows better
  • at the bottom of the dip stick there is either a valve or plug
  • open the valve or plug and let the oil drain (I use an old gallon oil container with a funnel) leave the dip stick out
  • while the oil drains; change the spin on oil filter
  • once all the old oil has drained replace the plug or close the valve
  • wipe down the funnel and use it to refill the new oil
  • use the dip stick to ensure proper fill level
I also recommend that you replace the air filter at the same time, if the engine can't get air is can't run efficiently.
If this is helpful please vote yes, Thank You!!
Sep 15, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Changing oil in my mtd lawn tractor!! Was oil should I use? Where is the filter? How do I change it?
Most Mower engines have an oil drain plug located at the base of the oil fill tube or dip stick tube, Most mower engines use a standard 30wt engine oil, however, to stay within the parameters of your warranty, use the manufacturers reccommended oil, this info can be located in your owners manuel.
Apr 14, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
Sep 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
348 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
