Question about QSC GX3 Amplifier
Channel two green signal ligth is faint on qsc gx3
4 Suggested Answers
Kuwagata
  • 181 Answers
SOURCE: My QSC GX3 has a red light that turned on (on the
You should check the speaker set, maybe it's short circuit.
Try remove the speaker set from the unit, than switch on the amplifier again, if the red light still on, surely the final drive is damages( Transistors or IC's).
Replace it with new ones.
Posted on Oct 18, 2009
  • 166 Answers
SOURCE: qsc mx 2000a left channel go into protek mode
Does it do it with nothing connected to the inputs and outputs? If yes, something internal.. anything loose in there (is it moved alot and something could have fallen inside of it)
Posted on Mar 28, 2010
  • 483 Answers
SOURCE: what kind a outputs transistor use a QSC Gx3 power Amp
this power amp uses 2SA1962 and 2SC5242 output transistors. You can download the schematic diagram from this website.
Thanks.
gylacz
Posted on May 11, 2012
Red light stay on no sound
Check for shorted speakers, if ok check output transistors for short
Dec 24, 2013 | QSC GX3 Amplifier
What kind a outputs transistor use a QSC Gx3 power Amp
Thanks.
gylacz
May 10, 2012 | QSC GX3 Amplifier
How do I bridge my QSC GX 3 amp to run one speaker cabinet?
For QSC amps the GX series are not bridgeable. You will have to run one speaker to each channel.
Mar 22, 2011 | QSC GX3 Amplifier
One channel's red led is always on and no sound
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/QSC-GX3-Amps-manual/id/23107ag606/t/2/
See page 7.
"CLIP: red, to the left of each Gain control.
Normal indication: illuminates whenever the amplifier is driven beyond full power. The LED's brightness indicates the amount of distortion. Distortion that causes only brief flashing may not be audible.
During muting, the indicator fully illuminates. This occurs during normal "On-Off
Mar 17, 2011 | QSC GX3 Amplifier
Qsc mx 2000a left channel go into protek mode
Mar 28, 2010 | QSC MX1500A 2-Channel Amplifier
My QSC GX3 has a red light that turned on (on the front panel). The channel is not working. Is this a fuse or something else?
Oct 18, 2009 | QSC MX1500A 2-Channel Amplifier
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
QSC 1420 pwr amp
The weaker signal caused by leaky capacitor and change value resistor is need to replaced with a new one so it's works normal again. Your tech did is re soldering the cold solder he did not replaced some defected parts.
Hope it may help you;
Regards;
VOTIT
Jan 07, 2009 | QSC MX1500A 2-Channel Amplifier
Long startup
There is a bad connection in the other channel or the speaker relay has a bad contact in it.
Sep 30, 2006 | QSC MX1500A 2-Channel Amplifier
QSC GX3 Amplifier Logo
52 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
