Question about Allok Soft Allok Video to iPod Converter
During converting, time out error - Allok Soft Allok Video to iPod Converter
Ford obd error code p0420
clogged catalytic converter, replace it with a new one, or remove old one, use a long pipe and punch a hole through it, empty out the pieces, and reinstall. That will work if you don't get the sniffer stuck on your exhaust during emissions testing, as your emissions will be very high using my pipe through the converter method.
Dec 16, 2013 | Ford E-350 Super Duty Cars & Trucks
A 1xx POST error code indicates a problem with the ??
It indicates a problem with the system boards. For more info, start here.
Oct 30, 2012 | HP Computers & Internet
After updating the program, the server computer does not allow access to programs. Error messages come up -6150 and-1006. the file directory list every file 3 times, with no access from file directory...
Looks like it can be caused by:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
You can convert the file to a .qbw which is a quickbooks working file
Jan 19, 2011 | Intuit QuickBooks Pro 2010 Full Version...
My lg kp500 phone has not work the files like mp4, flash files like .swf formats. Plse help me
For more details mail to me at: "sagarv6@yahoo.in" .swf files r not for viewing/playing in LG phones especially LG KP500.But they are used during format time/ during installing time. So, no need to bother abt it. But they support in some phones like Nokia, etc. Cmng 2 secnd prob, I think U hav the fies .mp4 files i.e., probably they might have been converted using a series60 phone's converter. so, check it out using another converter.
Mar 19, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Hesitation at 40mph and 50 mph.
A pop and hesitation is likely a backfire. The hesitation around 40 and 50 would be in keeping with that theory. There are several reasons you might be getting backfires and hesitation. If your ECM is adjusting the engine to run too rich this could happen. Misfiring might be occuring. Timing could be out. But one of the most likely is a restricted exhaust, likely due to a plugged, damaged or worn out catalytic converter. In some cases the converter may be bad enough to be giving you some performance problems, but not yet quite bad enough to signal an error. A vacuum test can help confirm whether this is exhaust related.
Feb 07, 2009 | 1997 Dodge Caravan
Error 232*
Error 232 Severity 16
Error message text Arithmetic overflow error for type %s, value = %f.
Explanation This error occurs when Adaptive Server detects an arithmetic overflow error during execution of a SQL statement. Arithmetic overflows occur when a variable has too few places to store the converted data. In particular, Error 232 is raised when an overflow occurs for a variable of datatype float.
Error 232 can occur during execution of the convert function. It can also occur during implicit conversion within Adaptive Server, either during a stored procedure run or during execution of a SQL statement which converts a float value to some other datatype.
Action Determine which variable is causing the problem based on the datatype reported in the error message output and the SQL statement on which the error occurred. If the error occurs within a stored procedure, an additional error message will be displayed showing the name of the stored procedure and the line number where the error occurred.
Increase the size of the variable that is causing the error. If it is in a procedure, re-create the procedure.
If this error occurs on a Sybase-supplied system stored procedure, contact Sybase Technical Support.
Versions in which this error is raised
Jul 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Jul 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
Computers & Internet Logo
Top Allok Soft Computers & Internet Experts
David Payne
David Payne
Are you an Allok Soft Computer and Internet Expert? Answer questions, earn points and help others
