Question about Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000
Need user manual for MOTOROLA IHF1000 - Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000
Can't answer calls using IHF1000 when paired with my iPhone. Green button just hangs phone up..
Press the big blue button in the middle. It will take the call but you have to wait a couple of seconds. Don't answer the call with the phone though as it will not transfer to bluetooth (it's a sort of privacy option)
Dec 04, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Need to delete paired phones from Motorola IHF1000 car kit
Hit the talk button. Say Setup Menu. Then Say Remove Phone (phone # you want to remove). Alternately, say "remove all phones", then re-pair just the ones you want.
Manual : http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/User_Guide.pdf
Jul 14, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
What to do
If you are sure that the handsfree system in your truck is an IHF1000, then long pressing ( >2s ) the center "talk" button on the IHF1000 will put the system into pairing mode. Follow the instructions that are spoken from the kit - have your phone scan for handsfree devices then, find the IHF1000, select it, then enter "1234" for the passcode and complete the pairing.
Jun 25, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Pairing an "universal" bluetooth to the samsung behold
Do you still have the user manuals for both the phone and the IHF1000? Start by reading the bluetooth pairing sections in both manuals and trying what is listed. If you have already done this, then please detail where you are having difficulty in the pairing process.
Apr 20, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
People can't hear me on my Blackberry Curve unless I turn the phone and talk loudly right into the speaker. I am so sick of having the "I can't really hear you" conversation! With my bluetooth, I have the...
When using the IHF1000 with your Blackberry Curve, I recommend to go into the device properties for the IHF1000 in the phone's Bluetooth devices listing. Under that, there should be a phone setting to turn Echo Canceller: On, Off, or Automatic. By default, it is Automatic. For this phone with the IHF1000, I would set it to Off. This has solved audio quality problems for a number of people.
Note: this may or may not directly address the low uplink audio level you are experiencing, but it does seem to help with general call audio quality when connected to the IHF1000.
Mar 06, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
MOTOROLA IHF 1000
You need to pair the carkit with your phone. Make sure the Bluetooth feature on your phone is set On, then follow the Pairing process outlined in the user manual.
Jan 02, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Microphone volume on Motorola IHF 1000
First thing, in your Blackberry's Bluetooth Devices list, find the IHF1000, then go to the Properties for this device. There should be a listing for Echo Cancellation - the choices are Automatic, On or Off. Set this to OFF. The IHF1000 has its own internal noise and echo cancellation - when connected the the IHF1000, your phone's noise and echo canceller should be turned off. This setting change will make sure of that.
Next, how and where is your microphone positioned? If you could post a link to an image I could view of how it is mounted, I can guide you further. Use tinypic<dot>com to post the image, or similar. Ideally, the IHF1000's microphone should be placed on the overhead console or domelight assemmly towards the front of the vehicle. It should be on the side of the console closest to the driver, and aimed at the driver. The cable comes out of the back of the microphone, so as a guide, the cable exit should be on the side of the microphone opposite of the driver.
Dec 31, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
Motorola IHF1000 bluetooth
Hey mawcab,
Based on the information provided it sounds like your microphone is not working. There a possibility it could simply be unplugged from the car kit control module. It will look like a head phone plug. If your car kit is aftermarket it was probably installed under the steering column. Check for a black box with an unplugged wire.
What type of work was done on the car?
Hope this helps!
Nov 05, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000 Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
