Question about Belling 3 cu. ft. / 85 liter Upright Freezer BE809
Belling 2626 TYpe HZDI 2626
Hi I have a Belling BCF10 chest freezer. The power light is not lighting but the freezer is still freezing, what is wrong? Also when should one use the fast freeze switch? Thanks in advance
If the freezer is working properly then the circuit that feeds the power to the power light is not working or the light itself is burned out. Either one or the other.
Sep 17, 2016 | Belling Freezers
I have a belling chest freezer BCF 20 ... It has an orange fast freeze switch is this switch left on all the time????
No. That is like running it on "high power" full time and could cause it to wear out and stop working much sooner than it's natural life expectancy. It also uses up more than twice the electricity on your electric bill, than it needs to work normally. That setting could also be used in something like a store, where people open it up every few minutes, to keep it cold when it's opened so often.
That switch should only be used for emergencies, like after a power outage, or to quickly freeze foods that were fully thawed and need to be frozen quickly.
Oct 14, 2013 | Belling Freezers
Our refrigerator is making the bell sound when the door are close
if it has belling system ,it bell alert when the door closed or otherwise you read the catalogue there must be written of this problem solution.
Mar 23, 2013 | Samsung RS261MDBP Side by Side...
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
Temperature control are the lower numbers colderr or warmer?
Hi there, the higher the number the colder the fridge, unless the numbers are in degrees. If it's numbered 1-6, 6 is the coldest. -Alex
Aug 17, 2011 | Belling 3 cu. ft. / 85 liter Upright...
How do I get to the thermostat on a belling be809?
u can get parts online just put be809 thermostat and your area were u r too. it should bring a list of shops ect to buy it from ...try ebay too. or if you are in uk i can order it and send to u. bsc appliances 07779933829
Feb 27, 2011 | Belling 3 cu. ft. / 85 liter Upright...
Just bought Belling Chest Freezer Model BCM31 as old one was thick with ice, but new one is frosting up very quickly as well above food line. Is this normal? Setting is right in the middle.
open the lid and using a spirit level check that the unit is flat and that its not "twisted" then using an a4 piece of paper check that the lid sits flat all round with no air leaks (the most common cause of chest freezers frosting up)if you have one, a freezer thermometer is a good investment, as you can set the unit to run at -18C,the optimum temp,,,
Sep 06, 2010 | Belling Freezers
Belling freezer wont freeze, red light remains on all time. Turned on and off, adjusted temperature setting, cleaned but nothing makes any difference. Can hear pump working but does not cool.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 06, 2010 | Belling 3 cu. ft. / 85 liter Upright...
Had theoverload and relay switch replaced still tripping breaker
yes. if you pull all the wires from compressor and use a meter with a continuity bell , touch a copper line and then a compressor terminal. try em all. odds are you'll hear a bell showing continuity or the fact that power can flow directly from the compressor terminal to the chassis= a grounded compressor. or you could have a dead short where the wires in to the compressor aren't touching the case but are touching each other before they go to the motor windings, = a short. either one is an all done situation. time for new .
Nov 19, 2008 | Hussmann Commercial Freezer DCCG-12
Belling be810
Hi the problem is with a clogged drain hose that's why all the water. to unclog turn off fridge. pull away from the wall . remove back panel. clean all vents . locate drain tube, by the drain tray. clean out the drain . thanks the appliance doc
Oct 06, 2008 | Belling Freezers
Belling 3 cu. ft. / 85 liter Upright Freezer BE809 Logo
112 people viewed this question
Top Belling Freezers Experts
AJMAL KHAN
James Coghill
Tom Chichester
Are you a Belling Freezer Expert? Answer questions, earn points and help others
