Question about Cuisinart CGG-240 All Foods Foll-Away Gas Grill
What is the chain and wire for on the CCG-240 gass grill
Not listed in assembly instructions...
What is the chain for in a coleman road trip sport grill
It is called a Match Extension. It lets you use an ordinary book match to light the burner by placing the lit match in the wire loop and holding it near ththe burner
Jun 10, 2012 | Coleman RoadTrip Sport Grill 9944-851
I am trying to assemble a grillpro H stainless steel replacement burner 16" model 23515. What does the cross leg for instruction number 2(c) look like? It would help to have a parts list with...
Unfortunately an Owner's Manual or Parts Breakdown for your Model Grill Pro is not available on line. However, you can contact OMC, the manufacturer of your grill 1-800-265-2150 and they can help you.
Thanks for choosing FixYa.
Aug 08, 2011 | GrillPro Grill Pro 23515 1512Inch...
Bought this product but there is no assembly instructions or owners manual in the box is there a place to view it online?
Here's a link where you can download free Ducane manuals. Hope they have your model listed. Douglas
http://outdoorcooking.manualsonline.com/manuals/mfg/ducane/ducane_gas_grill_product_list.html
May 14, 2010 | Ducane "Affinity 4400" Propane Grill
All the replacement burners I see are the H pattern,mine is straight and I don't see one listed.where do I find the right burner for my magnum 240 grill
i have one digital media player make blu sens he is show the message on screen insert usb line and press ok key to use usbdisk, press other key to cancel usbdisk. I am how to slove this
Mar 17, 2010 | Fiesta 240 Grill
I just need a wiring diagram---with a thermostat-- for a cadet FX-152 , 240 volt ,1500 watt wall heater
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
Jan 15, 2010 | Cadet Manufacturing CADET SL Series Small...
What is the chain on the side of my grill for? Kenmore Grill with 100% Infrared Cooking System Sold by Sears | Sears Item# 07116650000 | Model# 464222209
I have either the same grill, or one very similar (Kenmore infrared grill) and just assembled it yesterday and had the same question! I don't believe it's a safety chain. It hangs from the left front corner of the main grill body, and it has some sort of curled wire thingy on the end of the chain. The chain is definitely not thick enough to secure the grill. I looked through the assembly instructions a few times and could not find reference to what it's for. Any other ideas?
Jan 03, 2010 | Ovens
The wire on my grill caught fire. Now it will not light. What can I do?
You'll need to replace the igniter wire switch assembly. you can usually find them at the hardware store pretty cheap. follow the instructions and make sure the wire is properly shielded from the heat.
Jul 12, 2009 | Weber Genesis Silver B Grill
I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Mar 19, 2009 | Grilling
Chain
It is used to maually light the burner with a match. The match goes in the "loop" part. It is attached so that it isn't lost/
May 12, 2007 | George Foreman GP324 Stainless Steel Grill
Cuisinart CGG-240 All Foods Foll-Away Gas Grill Logo
52 people viewed this question
Top Cuisinart Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Cuisinart Grilling Expert? Answer questions, earn points and help others
