Question about Xerox 7800/DX New
7800DX not printing one particular file; error code 389.601.00
I am trying to print an InDesign CS5 file (set up to print tabs) from a Dell Optiplex GX620 that is connected to a server; the 7800/DX is connected to the same server. I have no trouble printing other files (InDesign, Photoshop, Illustrator, PDF, Word, Excel). The printer front panel says it is printing this file but nothing comes out and it will show the same status for as long as I let it. The Fault History shows multiple instances of 2 error codes, but the "details" page only shows the print count and the date the error occurred. It provides no actual details. The two error codes are 389.601.00 and 389.603.00. Can someone at least point me to a list of error codes so I will know exactly what is going on?
4 Suggested Answers
  • 208 Answers
SOURCE: Xerox Paser 7700 not printing seemingly large files from CDR13
Have you tried downloading a different driver?
Sounds like that may be the problem
Posted on Dec 04, 2007
SOURCE: I can't print full bleed from CS3 to a Phaser 7750DN
You didn't mention paper size, so my apologies if you are using a sheet that will accommodate bleeds and just didn't mention it. This is the simple answer.
If you printing on 8.5 x 11 paper, you can't get a full bleed. You'll need to print on a larger paper size, like tabloid, and trim your 8.5 x 11 size out of that. There are no printers, even commercial offset printers, that can bleed an 8.5 x 11 design on an 8.5 x 11 sheet. There must be trim in order to get the bleed. it 'bleeds' off the edges of the design.
Posted on Nov 12, 2008
  • 2072 Answers
SOURCE: Got error when print to Xerox phaser color printer
If the printer does not have a hard drive. Pdf will be hard to print.
Second, Are you using a PS driver or PCL? If PCL change to PS.
Here are some direct printing setups also.
To download a PDF file directly to the printer from Windows 2000 / XP / Server 2003:
To download a file to a printer that is connected using an Ethernet (network) cable, use the FTP command or CentreWare Internet Services (CWIS). To download a file to the printer that is connected directly to the computer with a USB cable, use the Xerox File Downloader Utility.
To download a file to the printer using the FTP command:
NOTE: To perform this solution, the printer must be connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
Not all web browsers can be used to perform this solution. If problems occur when performing this solution, download the file using CWIS. See the To download a file to the printer using CWIS section below.
  1. From the computer, open an Internet browser window.
  2. Type: ftp://xxx.xxx.xxx.xxx, where the x characters represent the IP address of the printer, in the Address field.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below for additional information.
  3. Press [Enter] on the keyboard. A blank FTP connection window with a [.] icon will be displayed.
  4. Drag and drop the file to be sent to the printer into the blank FTP connection window. The file will be sent to the printer.
To download a file to the printer using CWIS:
  1. From a computer, open an Internet browser window.
  2. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below.
  3. Click on the [Print] button.
  4. Click on the [File Download] link in the list of options on the left side of the window.
  5. Depending on the browser being used, click on the [Browse] or [Choose File] button, and then browse to and select the file to be downloaded to the printer.
  6. Click on the blue, square button to send the file to the printer.
To download a file to the printer using the Xerox File Downloader Utility:
NOTE: This solution assumes the Xerox File Downloader Utility has already been installed on the computer. If necessary, click on the [Drivers and Downloads] link under the Product Resources menu on this window to download and install the utility.
  1. From the computer, open the Xerox File Downloader Utility. By default, the utility is installed in the following location on the computer's hard drive: C:\File Downloader.
  2. Select the required printer from the Select the printer to spool the file to from the list below pull-down menu.
  3. Click on the [Browse] button, and then browse to and select the file to be downloaded to the printer from the Select the file to sent to the printer section.
  4. Click on the [Send] button to send the file to the printer.
To download a PDF file directly to the printer from Macintosh OS X:
Files can be downloaded to the printer using the Print Center or Printer Setup Utility, or by using CentreWare Internet Services (CWIS).
To download a file to the printer using the Print Center or Printer Setup Utility:
NOTE: This method can be used for Ethernet (network) and USB connections.
  1. Open the Print Center (for Mac OS 10.1 - 10.2.x), or the Printer Setup Utility (for Mac OS 10.3.x and 10.4.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on the [Print Center] or [Printer Setup Utility].
  2. Double-click on the printer that needs the file sent to it. The print queue window will be displayed.
  3. Drag and drop the file to be sent to the printer in the print queue window below the Name column. The file will be sent to the printer.
To download a file to the printer using CentreWare Internet Services (CWIS):
NOTE: CWIS can only be accessed if the printer is connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
  2. Enter the printer's IP address in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
Posted on Jul 13, 2010
Xerox Phaser 7800DX not printing one particular file; error code 389.601.00
Make sure your are using Postcript Driver & not the PCL6 driver and that the document page size and the paper page size in trays are the same.
Dec 26, 2013 | Xerox Phaser 7800/dx Workgroup Laser...
We are having problems printing a 10' x 42" banner on our Epson 10000 plotter. We are using a Xante Symphony RIP networked to the Plotter. For some reason it stops printing at approx. 76% (3/4) of...
STEVE you have to print it as a tiled image. there is an update on the epson website for this issue. basicly anything over 90" you have to tile as two images split in half with no border in between if that makes sense. they explain it well in the update. when its something 120" x 36" lets say i run the set up at 36 x 60 then go to the page set up and there should be a box for tie image when you preview it again it shows the tiled image put back to back. you also have to tell it toreverse the print. i use adobe cs2 illustrator and it works well.
May 28, 2011 | Epson Stylus Pro 10000 InkJet Printer
Indesign CS5 is performing extremely slowly on my new imac with 16GB Ram.
Try Repairing the Permissions on the Mac.
1: Click on Finder
2: Click on Applications
3: Click on the Utilities folder
4: Click on Disk Utility
5: Click on Check Disk Permissions
6: Wait for scan to look for errors
7: When done, click Repair Disk Permissions if there are errors
8: Close Disk Utility and see if your problem is solved
Mar 03, 2011 | Adobe InDesign CS5 for Mac (65062470)
Codes for Adobe Indesign CS5 thanks
Adobe InDesign CS5 serial:
1037-1526-7617-2987-8903-5117
Nov 10, 2010 | Adobe InDesign CS5 Upsell from Pagemaker...
ERROR 016-720 FOR DELL
The problem correspondent to this error code is: "Error relating to PCL emulation problems occurs."
The solution is: · Press the "Return" buttonto clear the message, cancel the current print job, and conduct the next print job, if any. Press Cancel to cancel the print job.
Mar 30, 2010 | Dell 3100cn Laser Printer
Problem: When I save indesign file as a pdf, the printed pdf shows boxes that were transparent in the original design. Are there settings somewhere that allows what was transparent on the screen to stay...
You did not indicate your version. I will assume you are using CS4.
In you print dialog, there is a transparency Flattener. Adjust it to high resolution.
Oct 04, 2009 | Adobe InDesign
InDesign Cs - create A5 booklets for printing on A4 paper
there's the function PRINT BOOKLET under the file menu
Nov 07, 2008 | Computers & Internet
InDesign Printing problem; service error 49.4c02
This is a solution which has been suggested on another site, this has not been tested by myself so no promises.
1. Turn the printer off.
2. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
3. Remove all EIO devices from the printer.
4. Turn the printer on.
5. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
6. Replace a DIMM or EIO device if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
Hope it helps, as I said, not tested personally.
Jun 19, 2008 | HP LaserJet 4350dtn Printer
Xerox 7800/DX New Logo
634 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
