Question about ASUS Essentio Computers & Internet
I need to know how to get into safe mode on a asus essentio desktop
I need to do a system restore from my recovery disks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
As soon as the screen comes up that tells what kind of computer you are using when you start the computer, keep tapping the F8 key and that will bring you to a menu with choices of safe mode, safe mode with networking, and restore to last known good configuration.
Posted on Apr 23, 2014
cpenzes
  • 1102 Answers
SOURCE: PC keeps restarting - cannot get into safe mode or system restore
i'll help
Posted on Jan 17, 2009
  • 2692 Answers
SOURCE: Running Vista system restore 8hrs (not in safe-mode)
I am fairly sure that if you stop the system restore mid stream it  will just resort back to where it was w/o any problems.  Then you can restore in safe mode. If it took that long ,if I were you , i would go and clean the harddrive or run check disk or download hard drive tools from;    seagate.com      and check the hard drive .  Your other option is to use you restore disk and restore the whole thing. If the hard drive is bad you will ending up doing this after you install a new hard drive.
bootz84
  • 197 Answers
SOURCE: I want to restore my Acer Aspire M1100 desktop
You'll have to use your recovery disk to set it back to factory, unfortunately most recovery disks give you little or no options for which software is to be reinstalled. The only way to install windows without any of the extra software that your computer came with would be to take a standard windows installation disk and install through that. Afterwards you would have to manually install all the driver software.
Alternatively, you can install with your recovery disk and use the add/remove software feature in the control panel to remove any programs that you do not want, just be sure that you don't remove any software that is a driver for any hardware devices.
Hope this helps, get back to me if you need any more information.
Posted on May 06, 2009
  • 7 Answers
SOURCE: Unable to reinstall DVD backups after HP SYSTEM RECOVERY failed
Code "purple" means you and your computer are done. It is an unrecoverable error that means you need a new system. However, I have found a couple of postings that claim to know a fix. I can not verify these methods, I do not own a HP or other type of prefab PC (custom is the only way to go). Anyway, here are the links, good luck.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=6115
http://forums.techguy.org/windows-nt-2000-xp/469752-code-purple-configuration-error-hp.html
http://forums.techguy.org/all-other-software/644163-code-purple-advice.html
Posted on May 16, 2009
djfrankn
  • 100 Answers
SOURCE: Can not get the Recovery Disks to restore my system,
Ok. What you have here is:
1. A bad Hard Drive.
2. A so corrupted files due to several factors including the possible hard drive failure.
Try to remove it from the pc and mount it on another one as a secondary hard drive or better as a slave (you can find a way to do it on the web, explanation is too long). Or, get your self a Hard Drive External Enclosure and mounted on it and connected to another pc as ay External Hard Drive (to me, the external enclosure is the best choice since you can use them for different hard drives and is just a swap out procedure, pretty simple). Either way you do it, if your pc can load it up, run check disk utility for it. That, for the most part, should fix some files to let you access it and do a back up. If I was you and if you succesfully save all the stuff you want to save, I would reinstall the Operative System from scratch. If it fails to install or gives you problems after the fresh install, get a new Hard Drive. Good luck.
P.S.: If my explanation helped you, please leave a review.
Posted on Jan 10, 2010
Testimonial: "Thanks for the information, it wasn't exactly what I wanted to hear but better than being frustrated going through the motions for nothing. "
Asus system factory restore
Hi
System Recovery Using the Parttion
* Press F9 on booting up (right after you power on and see the ASUS logo), you should now be able to access system recovery. (This is the sys-recovery combi on my ASUS.)
All you need to do is to read carefully before clicking any button upon system recovery process.
NOTE: This is only if you have left intact your system recovery partition. If you have formatted or deleted that partition, you will have to get the recovery cds.
Dec 29, 2011 | ASUS Essentio Desktop / AMD Phenom II X6...
I had it wiped from a virus a month ago. It hasnt been working very well since, it keeps shutting down, i keep restarting it and keeps shutting down. I have just left it alone shut off for at least two...
Attempt to restart the computer to get it to start up normallly.
If this does not work then you may have to install new windows to correct the issues the virus may have caused.
May 14, 2011 | ASUS Essentio Desktop with Intel Pentium...
I have a asus essentio series how can i restore it to its original state to as when i bought it
you will need to locate the "restore disk" that you should have gotten with your machine. You need to boot from that disk and follow the instructions that are on the disk. WARNING....restoring the machine to factory state will most likely erase all your data. There are more detailed instructions if you check google, and the asus site. Overall if you can successfully boot the machine from the disk it is pretty simple.
Good Luck
Apr 19, 2011 | ASUS Essentio Desktop / AMD Athlon II X2...
I Want To Rest My Computer To The Factory Settings, I Have ASUS Essentio Desktop Model #CM1630-06, Please Help Me. Cleon
1. if you have windows operating system then go to your start button 2. search for backup 3. go to backup and restore 4. choose the restore factory settings or if it says recover system settings then choose that one
Apr 04, 2011 | ASUS Essentio Desktop / AMD Athlon II X2...
Hi I am trying fix my niece's ASUS eee T91 which goes to a black screen with a cursor on booting up. I get no response at all after this. I can press shift and f10 to get into bios setup but dont...
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the laptop. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Also, you may try to boot in safe mode. Tap continuously the F8 when you turn ON the laptop until you reach the advance boot option. Select safe mode and let it load. Once loaded in safe mode, do the system restore. To do system restore, follow this:
  • Open System Restore by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, clicking Accessories, clicking System Tools, and then clicking System Restore.? 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If it does go to safe mode or if same problem will persist after the system restore. You need to do system recovery or reformat the system. Some laptops provides Recovery disc, some has it on the HDD. You may contact ASUS tech support to know the recovery option for your model.
Good luck.
Mar 14, 2011 | ASUS Eee 4G Notebook
My computer won't open windows i can only open it in safe mode.
In safe mode try run your AntiVirus app.If you can,t you problably had a bad infection the i think you will nned a BOOT Disk to restore the OS.
Oct 03, 2010 | Computers & Internet
How to boot asus 1005ha in safe mode
Hold F8 While turning pc on and select Safe mode
Jun 22, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Restore to factory settings from recovery disc
ok providing you have a restore disk here are the steps that you need to take
first thing is that you have to start the computer and (depending which computer you have) hold the f12 key it will show which you would like to boot first menu (make sure your vista disk is in) goto boot cdrom fist follow instructions this should get you back in to reformat and reloading vista
Dec 10, 2009 | ASUS Essentio Desktop with Intel Pentium...
Unable to restore
You are really not giving enough information to be of good help.
What kind of restore have you tried to do? Have you tried to restore from MS Backup ?
Is this a system restore.?
Anyway, if you have your system restoration disk, install it and fallow the prompts.
Or is you are restoring from vista, type recovery manager and select from the list of items.
If you are trying to do a complete restore, choose that item.
Oct 22, 2009 | Acer Computers & Internet
I have a Eee PC and it is hungin a loop. It stays in safe mode then acts like its going to windows xp then goes back to safe mode
While it is in safe mode, restore it to an earlier date. How??? Start-> accessories->System Tools->Restore.
Sep 26, 2009 | Gateway 838GM (RB838GM) PC Desktop
Computers & Internet Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
