Question about Nintendo GameCube Console
System error stops playing and tells u that a system error has occured.? Refer to owners manuel. Do not have manuel. Does this mean that your machine is fried?
  • Haleydaisy Dec 26, 2008
    no. mine has done this too but only with one game which i got used as a christmas present so i just assume it doesn't work. when i put it in, it says "error, read owners manual". but all the other games work. try putting in other games. if these still don't work, ask a worker at gamestop or something.
  • 94 Answers
Maybe it has just worn itself because it is quite a old console , hope i helped
Posted on Oct 17, 2007
SOURCE:
Ie error what does it mean
when an error occurs the system is telling you that there is something wrong with the machine before it can proceed
eg., no water present , faulty spinning ( motor breaking down or clogged up ) heater element not working . entry door switch not working or door not properly shut these are just some of the errors
Jan 01, 2018 | Washing Machines
Error occured press hold power
I've got that message before. What that means, is that sorry, but you won't be able to play that game ever again. What causes this is that the firmware in the update blocks some things that Nintendo wants to be blocked, so they block it. There's a simple solution though: You won't be able to play this game. (This happened o me with Action Replay)
Jun 16, 2013 | Nintendo DSi Black Console
I put in my dvd on my magnavox blue ray player and it says disc error then something like disc not recorded for thins region code * 2 * 45 *
DVDs are recorded for three world regions (for copyright reasons and to match the electronic TV system also broadly in three world regions known as PAL, SECAM & NTSC)
You're likely in the USA as you refer to the Magnavox brand.
Your region is 1 and system NTSC.
Your machine is correctly telling you it can't play the disc because it's for Region 2 system PAL.
However, there are multi region players available, for a few dollars more, which play discs of any region or system.
Sep 20, 2011 | Audio Players & Recorders
Please help. i have 2 dsi 's and my red one will let me play my game but my white one will say: An error has occured. press and hold the power button to turn the system off, please refer to the nintendo...
Unfortunately, this may mean that your DSi is broken. You will need to get it repaired/replaced by Nintendo. You can call them at 1-800-255-3700 for a pricing estimate.
May 01, 2011 | Video Game Consoles & Games
We have an error meassge 44 when faxing using the Panasonic Laser KX-FL541 to someone else. Can you please tell us what this means? Thank you so much,.
COMMUNICATION ERROR
(Code: 43, 44)
* A line problem occurred. Connect the
telephone line cord to a different jack and try
again.
* An overseas transmission error occurred. Try
using the overseas mode (feature #23, page
47).
here is the pdf file(manuel)
http://service.us.panasonic.com/OPERMANPDF/KXFL541.PDF
Mar 22, 2011 | Panasonic KX-FL541 Plain Paper Laser Fax
My action replay dsi says "An error has occured. Please turn off system and look up troubleshooting in the manual." Or something like that. Suggestions?
if your action replay ds still says error has occurred please refer to operations manuel for details even after i clean it what do i do
Feb 03, 2011 | Datel Action Replay for Nintendo DS
Game disc wont play
Is it just one game in particular? if so refer to the people who make the actual game, if its more than one game, then contact nintendo and talk about getting your system repaired, if its under warranty( one year ) you should qualify for a free repair.
Jan 23, 2009 | Nintendo Wii Console
When I try to play a C.D. on my system it gives me the following information. FRMTREAD, Error 15. What does this mean and what do I do to correct this problem? My system is a DEH2000MP S.N....
Consult your owner's manual for error codes. You have a disk/disk reader problem. A similar model Pioneer Manual indicates FRMTREAD as what is displayed while reading a disk. Error 15 equates to "The inserted disk does not contain any data". If this occurs with multiple disks, try the disks in a known good cd player. If they work there, it is likely a reader problem (alignment, bad reader, etc.) which would likely not be worth repairing or replacing in that unit.
Jun 23, 2008 | Pioneer DEH-P2000 CD Player
Bsod when i tried to install win2k
Error Message: PAGE_FAULT_IN_NONPAGED_AREA
Explanation:
This Stop message occurs when requested data is not found in memory. The system generates a fault, which normally indicates that the system looks for data in the paging file. In this circumstance, however, the missing data is identified as being located within an area of memory that cannot be paged out to disk. The system faults, but cannot find, the data and is unable to recover. Faulty hardware, a buggy system service, antivirus software, and a corrupted NTFS volume can all generate this type of error.
User Action:
This Stop message usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, either main memory, L2 RAM cache, or video RAM). If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. Run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Another cause of this Stop message is the installation of a buggy system service. Disable the service and determine if this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows 2000 Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time. Antivirus software can also trigger this Stop message. Disable the program and determine if this resolves the error. If it does, contact the manufacturer of the program about a possible update. A corrupted NTFS volume can also generate this Stop message. Run Chkdsk /f /r to detect and repair disk errors. Restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk. Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver causing the error. Disabling memory caching of the BIOS might also resolve it. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at http://support.microsoft.com/support.
Nov 20, 2007 | Microsoft Windows 2000 for PC
Nintendo GameCube Console Logo
42 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
