Question about Maytag Washing Machines
Maytag MFW9700SQ washer fill with water after turned off
After washing clothes and left overnight, with door open, washer has filled partially with water. (turned off)
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer fills with water when not being used
Water accumulating in the tub is usually caused by two things:
Leak by - which is caused by a water inlet valve malfunction. The valve has an electronically controlled diaphragm that closes to shut the water off when not in use. Over time the valve can accumulate sediment and debris causing the valve not to seat all the way. This is especially true if you live in an area that has hard water, or if you use well water. This will cause water to leak by when the valve is not in use and accumulate over time in the wash tub. You can attempt to clean the valve with distilled vinegar to remove any sediments and flush it with clean water. You will need to remove the valve in order to do this. Sometimes a good cleaning is all it takes to correct the problem. If not, I would recommend replacing it.
Siphoning - siphoning occurs when the drain line is installed incorrectly. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although the problem usually describes a condition where a washer constantly fills and drains, or cannot maintain the proper water level, it can also cause back flow from the drain. Double check your drain line installation to ensure there is a proper air gap to allow for proper draining. If not, a vacuum is created and drain water can back flow into the washer.
A simple test would be to shut the water supply off when not in use. If the washer STILL accumulates water, you know you have a drain problem. If it does NOT, then you know you have an inlet valve issue.
If you need to replace the water inlet valve, replacements can be ordered on line at searspartsdirect.com. Just type in your model number and look under the "Dispenser Parts" heading for item number 1 (part #8181694).
It is a very simple process to replace. Just follow these steps:
1. Shut off water supply and unplug washer.
2. Disconnect fill hoses from the back of the washer.
3. Remove washer top panel by removing the three screws that hold it in place in the rear. With the screws removed, the panel slides back, then off.
4. The water inlet valve is located in the left rear of the washer (as viewed from the front with panel removed).
5. Disconnect the dispenser hose from the valve and the mounting screw(s) and the valve is removed.
6. Install new valve using the steps above in reverse order.
It really is a very simple repair. I hope you find this information helpful. Let me know if you still require assistance.
Posted on Nov 18, 2008
duby1990
  • 367 Answers
SOURCE: MY WASHER FILLED UP WITH WATER, BUT THEN IT JUST QUIT WORKING.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Posted on Nov 21, 2008
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
venexcsd
  • 1185 Answers
SOURCE: Whirlpool Duet GHW9100LW1 fills up with power off
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Posted on Jun 06, 2009
canbruce75
  • 1776 Answers
SOURCE: my Kenmore Elite He4t front
This condition is typically caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 02, 2009
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
Lg front load washing machine does not seem to get the clothes clean. I think it is because it uses so little water??? How can it get clothes clean with just a few cupfulls of water? All controls and...
I have run into this problem several times with LG washers. On one job LG had us replace every electronic componet that had anything to do with the water fill and the problem still was not resolved. The electronic control determines how much water to fill depending on the load size, so smaller loads give you less water, with the same amount of soap. Leaving clothes in the washer overnight, and leaving the door closed does contribute to mold and fungi growth in the washer. The customer tried different brands of soaps and different amounts of soap. He left the door open after usage to allow the unit to dry out, and tried different cleaners, to clean out the sludge build up. We determined that there just is not enough water to thoroughly clean the clothes. The sales store had to replace the washer with another brand. There is an ongoing class action lawsuit against Lg for this problem. Do an online Search for lg washer lawsuit. By the way, we don't have a problem with clothes not getting clean with the Whirlpool Super Capacity Duet Front-Loading Washers. Good Luck, Appliance Specialists
Jan 04, 2010 | LG WM1812C Front Load Washer
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer is filling up with to much water...
possible fill valve is sticking open when filling after starting washer disconnect power and listen to see if water is still running in if so replace fill valve.. if water stops possible water level switch or small hose to switch plugged ..drain washer remove screws on each side of door frame front will pull off...small hose on some models was attached to pump housing and would become plugged with lint ckd for restriction in hose from bottom to top remove screws in console to acess other end attached to pressure switch
Aug 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
