Question about Avenir Handler Pro II Floor Pump
How do I change from presta to scrhaeder valve?
    Master:
  • 706 Answers
There is an adaptor the does the trick. Its available on ebay, amazon or at your local bike shop
Posted on Dec 12, 2014
Inflate presta valve
to inflate a presta valve you need to yurn the top part of the walve counter clockwise at least 3 turns. the pump you are using must be for this type valve,or you can by an adapter. spin pump nozzle on to valve, add aie , remove and tighten top of valve. presto!
May 08, 2014 | Trek 4900
How to attach bontrager pump to presta valve
This pump does not need any presta valve adapter, the head unit is a dual unit for both presta and schreader.
1. On the bicycle tube. Open the valve by unthreading the small metal cylinder located at the very end of the valve stem. DO NOT force the the bead to come off of its threading. A couple spins counter clockwise will do the trick.
2. Insert the valve stem into the filler head. The lever on the back of the filler head should be "down" at this time.
3. Connect the filler head to the valve stem by lifting the lever on the head "up".
4. The valve stem and the handle on the filler head are now in parallel to each other, basically inline with each other.
5. START PUMPING.
6. If loosing considerable air while pumping, Try reinserting the valve in to the filler head, deeper, for a more secure fit.
If the issue persists, use a presta valve adapter on the valve stem. Traditionally used to convert presta valve heads to schreader heads, for use with filler heads not compatable with presta. A one dollar part available at any bike shop. Usually used in a pinch while airing up at gas stations or with schreader only pumps.
Dec 27, 2012 | Bontrager Supercharger Floor Pump - cycle...
How do i use the schwinn airdriver 1100 pump
This pump is a bit strange to use. The valve in the filler head is odd in that it controls the flow of air in both direction...which is not a great design in my opinion...but it does allow for use in different filling applications. The trick is getting the pump into its different filling "modes"
For a Schrader bike valve:
1. Make sure the pump is in "tire mode" by blowing into the valve with your mouth. If you then pump the handle you should feel air filling your mouth.
2. Put the "locking lever" in the unlocked position, the unlocked position is when the silver metal lever is parallel to the air hose, or said another way it makes an "L" with the air outlet that goes on the tire air filling stem. To verify this is correct, look in the air outlet and move the lever from locked to un-locked, you will see slight change in the diameter of the outlet.
3. Push the air filler hole over the schrader valve really hard and make sure it is seated all the way down. Close the "locking lever" (silver metal lever should now be perpendicular to the air house and be in line with the air outlet... i.e. point straight out away from the tire filler stem.
4. Pump.
For a Presta bike valve:
1. Make sure the pump is in "tire mode" again.
2. Take off plastic caps off presta valves on bike tire.
3. Unscrew the little nut on the presta stem to allow the tire valve to open when pressure is applied (you can test this by pushing the stem in a little and air should escape, the nut holds the valve closed, so it needs to be loosened).
4. Take the adapter from the locking lever (silver metal lever) on the pump and screw it on the presta valve. The adapter is the brass looking thing. Screw the rubber gasketed side down on the presta valve.
5. Press the air pump tire filler outlet onto the adapter.
6. Close the locking lever to seal the filler head on the adapter.
7. Pump.
8. Unlock the locking lever and pull it off quickly.
9. Unscrew the presta adapter and screw down the presta valve nut but just finger tight.
10. Screw on the plastic cover cap for the presta valve.
To Fill a Ball:
1. Twist the ball pin filler out by rotating the gray plastic tab around until the ball pin filler is pointing straight out (in-line with the air hose).
2. Make sure the pump is in "Ball mode" by again blowing into the filler. Sometimes shaking the filler valve really hard is necessary.
3. Put the filler pin into a ball.
4. Pump.
Hope this helps.
Apr 27, 2011 | Schwinn Cycling
How do you inflate this tube with the presta valve?
The following link is a good explanation of inflating a presta valved tube if you have a pump with a presta valve head.
If you have an older pump that does not have a presta valve head, you can purchase a schrader valve adapter from your local bike shop that screws onto the presta valve and will allow you to utilize a pump with a schrader head.
A good explanation can be found here: http://bicycletutor.com/presta-valve/
Feb 18, 2011 | Cycling
How do you fill the tires on this bike. The valve stems are not typical bike tire stems. I am (obviously) a novice biker and have not owned a bike in several years. The pump I bought is a Schwinn pump...
There are two types of valve stems, schrader ( like the valve stems on your car ) and presta. See images on this page http://www.sheldonbrown.com/brandt/presta-schrader.html Since you are asking I assume you have presta valves. You can get an adapter to convert the presta valves for use with a schrader pump. Unscrew the small knurled nut on top of the presta valve to open it, press down and release the small top to ensure the valve is free to move. Snug up the top when it is full.
Dec 23, 2010 | Schwinn Midmoor 700c Men's Hybrid Bicycle
I have just purchased a Topeak Mountain Morph pump, which can be used with both Presta/Scrader valves. I have a presta valve on my bike, but am not able to inflate my bike. Not sure if I am doing...
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
Aug 25, 2010 | Topeak Morph Pump
Cannot get my brand new Topeak Joe Blow Sport pump to lock onto a Presta valve. I have locked the lever down, but it does not hold the valve. It is as if the Presta valve is too small for the pump...
They should be designed to fit both styles of valve, but you need to reverse the seal.
you should be able to unscrew the end, remove the sealing rubber and a plastic fitting that pushes on the valve, replace them the opposite way around ,and they will fit the presta.
Aug 22, 2010 | Topeak Joe Blow Sport Pump
I have a Zefal HP frame pump. I'm trying to inflate a tire with a Presta valve. It just won't inflate. It doesn't latch onto the valve and seems to big for the valve body. Is there a diagram available...
Let's hope you didn't force it and snap the plastic point off.
Most Zefal pumps come with a reversible head that can adapt to either Presta or Schreader (like on cars). You unscrew the barrel at the working end of the valve, carefully tap out the rubber cylinder and the plastic internal piece behind it.
Insert the plastic piece in either of two ways. Pointy part Out (for Schrader) or just a round opening Out (for Presta). Rotate the rubber piece correspondingly to show the large opening for Schrader or the smaller opening for Presta and place it inside the valve over the plastic piece. Screw the knurled barrel on tightly.
Aug 12, 2010 | Zefal Bicycle HPX 3 Road Frame Pump
Avenir Handler Pro II Floor Pump Logo
253 people viewed this question
Top Avenir Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you an Avenir Cycling Expert? Answer questions, earn points and help others
