Question about RCA L26WD12 26 in. LCD TV
My rca tv model L26WD12 wont turn on. there is a red light on
The red light is on however the tv wont turn on
gregjr_pl1
  • 138 Answers
SOURCE: Everytime I turn the RCA
You have problem with your power supply. A blown up capacitor need to replace. somewhere in the output of the power supply.
Posted on Aug 13, 2011
jtrag
  • 112 Answers
SOURCE: RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Posted on Jul 21, 2009
budmrtn
  • 11361 Answers
SOURCE: RCA L26WD12 26IN, LCD TV will not turn on, the red
It can be due to unstable DC power from the power supply due to bad caps, or bad main board (I had to replace my main board, and later on the inverter boards). You may want to think about putting money into this TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://s807.photobucket.com/albums/yy352/budm/RCA%20L26WD12/
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 12, 2010
walesarumi
  • 6993 Answers
SOURCE: rca tv modle #27v414tyx8. wont
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 12, 2011
vinceisaac
  • 2432 Answers
SOURCE: My 32" RCA LED TV is blinking the red light 5 times and not turning on... I have only had the tv one week?
just inform the supplier it was covered with warranty so you can availed it.
Posted on Sep 23, 2012
Tv wont turn on. The led light comes on when plugged in it buzzes' and then nothing . Led stays on no picture sound or anything. None of the capacitors are blown. ? rca model number L26wd12
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 04, 2015 | RCA Televison & Video
How can I get a RCA L26WD12 manual?
Are you needing a owner's manual as stated or a troubleshooting manual? A troubleshooting manual can be found here: http://www.manualslib.com/manual/138985/Rca-L26wd12.html
An owner's manual can be found here: http://www.umlib.com/brand/RCA/category/TV/model/L26WD12 or here: http://www.retrevo.com/support/RCA-L26WD12-TVs-manual/id/404ag703/t/2/
You can find module replacements here: http://www.shopjimmy.com/rca/l26wd12/
Sep 06, 2014 | Televison & Video
My tv is not CRT is LCD RCA Model L26WD12
Assuming you are not accidently sitting on the remote, I would say either the power supply or main motherboard has failed. Time for professional service or a new TV.
Jan 07, 2014 | RCA TruFlat 27F520T 27" TV
Rca tv wont pick up channles
Go to the menu and do a channel search
Sep 26, 2011 | RCA L26WD12 26 in. LCD TV
Everytime I turn the RCA L26WD12 26 in. LCD TV on it powers off and on a number of times before it finally stays on. Waited through the off and on cycle 26 times once.
Aug 13, 2011 | RCA L26WD12 26 in. LCD TV
RCA L26WD12 - for as long as we've had it, it would have problems turning on, being the light would turn green, but the screen would stay black. We'd have to unplug it and plug it back in. Eventually the...
The tv Tuner signal board is the causes and the problems.That the board,where the tv incomming broadcasting signal cable wire plug into it.U can do the basic things like take it aparts and putting it back together again?Yes,Tries websites like Shopjimmy.com,Ebay.com to buy a tv Tuner signal board for the replacement.
Mar 23, 2011 | RCA L26WD12 26 in. LCD TV
RCA L26WD12 26IN, LCD TV will not turn on, the red off light stays on with no response from the on off button or the remote, to get the tv to turn on I have to unplug and plug in the power cord five or six...
Aug 11, 2010 | RCA L26WD12 26 in. LCD TV
RCA L26WD12 26 in. LCD TV Logo
101 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
