Detrola record player
Replacement turntable needles
arthurroger
  • 170 Answers
SOURCE: turntable arm slides across record, Am. D.J.-1500
See what type of cartridge is installed in the arm. Manufacturers use common cartridges in turntables, such as Stanton, Shure etc. Detach the head shell from the arm (it usually slips right off via a locking ring and four-pin mini plug) Look for the manufacturer and model number on the cartridge. No need to remove it from the head shell. On most modern cartridges, the stylus (as they are called, rather than the needle) simply slips off and on. No need to remove the entire cartridge (via screws) and re-align it. In fact, many DJs bring a set spare cartridges and styli on a gig, already mounted in head shells, and simply interchange them as needed. When you have the make and model of the cartridge, go to Radio Shack or use their website to order a new one...or  two. Or go to Google and enter "phono stylus" as your search term. You will find reasonably priced styli for nearly every cartridge imaginable. I operate 50 year-old turntables and am able to find replacement cartridges and styli on line. Ebay also has a number of listings, by make and model of the cartridge. When the new stylus arrives, observe how easily the old one comes out of the cartridge- usually pull and slide - and slide the new one in. Re-insert the head shell on the arm, tighten the locking ring, and you're good to spin!
Posted on Jan 08, 2009
  • 104 Answers
SOURCE: No sound coming from turntable
most likely this is the switch that selects among cd/tape/radio/record player. it could be the preamp circuitry in the player as well. it would not be the cartridge UNLESS you cannot see a little rubber 'seat' up inside underneath the cartridge that pushes the stylus tip out and down towards the record just a bit. if this rubber 'yoke' (seat) is missing you will get no sound even when you touch the needle tip when the record player section is selected.
Posted on Feb 11, 2009
  • 104 Answers
SOURCE: Need free owner's manual for a Detrola record player Model KM837
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
You have probably done this, but I had same problem on one I was given with no manual. I couldn't get the turn table to turn and by accident I move the arm to the right, away from record and it began turning. Hope that helps.
Posted on Apr 22, 2009
Can i use a crosley stylus in my detrola km837 record player
Stylus will only fit into certain cartridges. You have two options here. You can look up the cartridge number and make on your Detrola. It should be on the cartridge somewhere. Then search for the stylus. Or you can remove the Detrola cartridge and fit a new cartridge and stylus. As long as the cartridge will fit into the arm of your deck, plus it's the right type - ie: magnetic if the old cartridge was magnetic! Or ceramic - again if the old cartridge was...
Then you can use any make or model cartridge you want. As the quality of the sound can be improved - albeit paying more money for it - by having a good quality cartridge and stylus, it might be best in the long run to change the cartridge.
Jul 15, 2015 | Crosley Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Lots of Turntable belts are very much universal. If they are the same size there's no reason to think it won't work on another make.
Dec 24, 2013 | Audio Players & Recorders
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
WHAT IS THE STYLUS NEEDLE MODEL # FOR A RCA SS4000 RECORD PLAYER
Your source for all your antique radio, record player, turntable and phonograph needs!
Record Player Needles
Welcome to our record player needles and turntable stylus page! We hope you find this page to be very friendly and useful in locating a replacement record player needle or stylus for your phonograph. Use the picture charts of the record needles, and the information request form to help you identify which record player needle or stylus you need.
When it comes to stocking needles, we carry and stock more than just the "top brands", "most often needed" or "most popular" like other places you'll find on the web. Our inventory is very extensive and broad. Ranging from sophisticated high end types to plain straight steel needles for antique crank or wind up models.
Aug 31, 2009 | RCA Audio Players & Recorders
Looking for a needle for a turntable
May 14, 2009 | RCA Lawton 841.662 Turntable
Feb 22, 2009 | Audio Players & Recorders
Jan 25, 2009 | Crosley CR248 Turntable
 Grubhead
Grubhead
