Question about Bissell LiftOff Revolution Pet Vac 37602 Vacuum
How do I fill the tank
How do I remove the water tank to refill
I downloaded the user manual from the Bissell site
Posted on May 18, 2009
Used bissell how do i know if parts are missing
The main water tank is two staged; you put clean water in and the flexible bladder allows the machine's pickup suction to fill. This removes the need for two tanks (but it's harder to clean out the suction tank area). Just remember to clean the filters each use. There's one on the underneath of the clean water tank cap and one under the FLOW INDICATOR cap. You may need to get a User's Guide. Try calling the Consumer Care at 1-800-237-7691 Hope that helps.
Apr 03, 2015 | Bissell Vacuums
I need to know why the Hoover Max Extreme keeps telling me t check the tank?
Hi! The solution and water goes in the top tank. Dirty water is suctioned into the bottom tank as you're scrubbing your floors. To fill the clean water tank, remove the clean water tank cap. The cap serves as a measuring cap for the solution. Fill the cap with Hoover carpet washer solution to the fill line. Pour detergent into tank. Fill the rest of the clean water tank with hot tap water and twist the cap back on. You are now ready to clean. Hope this helps!
Aug 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    Wear do you put the water
    Inside the main tank is another container for clean water.
    To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
    Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
    My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
    Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
    Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
    Take care
    Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
    Not putting out water
    Here's some trouble shooting tips that will help you figure out what's wrong with your Bissell Little Green Machine, and why the water won't spray out. You didn't mention how old the machine was, but if the machine is brand new, and you've never used this before, then you'll need to prime the machine for the first time.
    To prime the Little Green Machine, remove the hose after filling the clean water tank, and press and hold the trigger on the hose for approximately 45 seconds. This will prime the pump, and get the water flowing.
    If the machine is older, and you've already been using it, here's some other troubleshooting tips that you can do to try and fix the machine:
    Step 1. Fill the clean water solution tank with water, and remove it from the machine. With the tank removed, press the piston at the end of the tank that fits into the machine. The piston is the spring loaded part in the top of the water tank that is pressed upwards when the trigger is squeezed, which in turn releases water into the machine. Press the piston inwards with your finger and see if water comes out.
    Step 2. If water is released from the tank when you push the piston inwards, then your piston and cap assembly are fine. Next unscrew the cap to the clean water tank and make sure that the o-ring is present. This is the rubber ring that rests in between the cap and the tank.
    Step 3. If your o-ring is not there, you'll need to purchase a new a new o-ring and replace it. If the o-ring is present, screw the cap back onto the tank. Inspect the receiver to make sure there is no debris blocking it. The receiver is the part on the machine that the tank sits on top of. If you see debris here, remove any debris that could be obstructing the tanks piston.
    Step 4. After checking these three things, refill the tank with water, reinsert back into the machine and test to see if the water now comes out. If the water does not come out, move on to step 5.
    Step 5. Unscrew the two screws on the handle of the hose, and remove the cover that the two screws secure.
    Step 6. After removing the hose cover, inspect the hose that connects to the trigger assembly for blockages:
    Step 7. If blockages are found, remove the tube from the trigger, and blow through the hose to remove any blockages, and reinstall the tube back onto the trigger.
    Step 8. Reinstall the trigger assembly so that the metal spring's curved side is facing down so that it touches the trigger valve:
    Step 8. After reassembling the hose, turn the machine on again and try spraying the hose again.
    If none of these solutions fixed your machine, this most likely indicates that you need to replace your pump. The pump is the internal part that takes the water from the tank, through the hose, and finally sprays it out. The pump replacement is a moderately difficult repair, but if you'd like me to walk you through it, I'd be more then happy to do so.
    Please feel free to ask any follow up questions, or let me know if you'd like for me to show you how to replace the pump. I'm always more then happy to answer any question that you may have.
    If you found this helpful, please kindly rate my repair helpful so that other Fixya users with the same problem can easily find this solution. By rating the repair you are also encouraging repair professionals to continue posting free repairs. Thanks in advance,
    Chris J.
    GoVacuum.com
    Apr 09, 2010 | Bissell 1400 Little Green Pro Canister...
    Amounts of Solutions
    From the manual:
    1. Remove the Clean/Solution Tank by lifting it
    straight up, then away from the Lower Body.
    2. Unscrew the black cap at the bottom of the
    Clean/Solution Tank.
    3. Add one of the BISSELL Advanced Cleaning formulas
    for Deep Cleaning machines to the formula fill
    line on the Clean/Solution tank. Fill the rest of the
    tank with hot (not boiling) tap water to the water
    fill line. Replace and tighten the black cap.
    4. Place Clean/Solution Tank on Lower Body.
    The manual is available at retrevo.com, but you have to register to get it. It doesn't open up so that I can link you to it. It doesn't cost anything though.
    Hope this helps!
    Dec 08, 2008 | Bissell 1770 QuickSteamer Upright Vacuum
    Hoover Steam Vac
    take off dirty water tank look for small screen usually at the top behind tank remove debris from screen!
    Oct 19, 2008 | Hoover F7431-900 SteamVac Vacuum
    How to fill the clean water tank???
    The clean water tank cap is two-part. Unscrew the threaded ring and then pull out the center piece. There is a rubber gasket around the center piece, so it may take light force to remove it. Fill the tank with solution to the "solution" line, and fill with hot water to the "water" line. Cheers.
    Jun 21, 2008 | Bissell 1770 Quicksteamer II Upright...
    Bissell LiftOff Revolution Pet Vac 37602 Vacuum Logo
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
