Question about Regal Ware K6746S Kitchen Pro Bread Maker
I need a new kneading pin
Is it possible to order a new kneading pin for my bread machine?
  • annpotts Oct 22, 2007
    Your response was not helpful but I did find one on eBay.
  • 368 Answers
Hi Annpotts,
If this problem comes up again, you might want to try this alternative in case eBay doesn't have what you want, or if you want to contact the manufacturer.
For Farberware parts, service or manuals, go to
http://prc.prodregister.com/prodprotect/applica/
And click on "toastmaster" (lower-left portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/fw.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 24, 2009
SOURCE:
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
Bread machine model TR520, mixes the dough, stops for a long time, then starts mixing the dough again continuously without starting the bake cycle. This was on the french program. The machine is new...
By continuously do you mean forever, non-stop kneading? I'm guessing not. French bread is really nothing more than white bread dough kneaded for an extra long time. The extra kneading creates the chewyness common to French breads.
Hope this helps!
Jun 17, 2011 | Breadman TR520 Bread Maker
My Toastmaster TBR2 bread machine does not knead when started. It makes a tick-tock noise and the timer counts down but no mixing. The bread pan is positioned correctly. Why?
Make sure you are programming your machine correctly.
The Instruction Manual indicates three possible problems, none of which would seem to be your problem. Not plugged in, error message or kneading blade missing.
Suggest you review the Instruction Manual for programming your bread maker. Unplug your machine to reset and then plug in and program as directed.
TRB2 Instruction Manual:
http://dl.owneriq.net/4/4ae504be-4834-4845-a8f8-7a6df62c1033.pdf
Jan 22, 2011 | Toastmaster TBR2 Bread Maker
I need a replacement kneading blade for my TBR15 toastmaster breadmaker. How can I order one?
You could buy it from :-
http://cgi.ebay.com/Toastmaster-TBR15-TBR2-PADDLE-Bread-Machine-Blade-NEW-/310145056299?pt=Small_Kitchen_Appliances_US&hash=item483615fe2b
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2010 | Toastmaster TBR15 Bread Maker
Need to order kneading blade for toastmaster bread machine TBR 15
Put this item number (310145056299) into an ebay search and it will find it for you. Looks like they are New paddles.
Dec 01, 2009 | Toastmaster TBR15 Bread Maker
I have a brand new West Bend "just for dinner" bread maker. In the bottom, the two-pronged part which the motor is supposed to turn, doesn't turn. Thus, the kneading spatula doesn't turn. The heating unit...
If the machine is brand new, then take it back for an exchange. If that's not possible, then call West Bend for a replacement. If that's not possible then let's try to solve this problem in a few steps. 1) Take pan out of machine and see if you can spin the paddle on the shaft. If yes...next step..if no then bearing in bread pan is stuck. 2) Put bread pan in machine and lock in place. Start a kneading cycle. Look through plastic lid to see if paddle turns. If no step 3. 3) Take pan out of machine and start kneading cycle. If motor shaft does not turn, then the belt fell off the pulley in the machine or belt is broken, or the motor is bad
Hank
Nov 15, 2009 | West Bend 41077 Just For Dinner¿...
Bread pan pops out during kneading, hard to remove after baking
I have Breadman Ultimate for over 12 years now. I make bread 2-3 times a week for the past 10 years. I found that the bread pan popping out only happens when the motor shaft and the kneading paddle are not tightly engaged. I find this problem in the following two scenarios: 1. The bread pan was not pushed down all the way as described by cassie_hobbs and tlcquiltnut. 2. Debris filled up the motor-shaft bowl underneath the bread pan to prevent a tight engagement of the motor shaft and the kneading paddle. These debris are generated during the kneading process; part of the ingredients is pushed out of the shallow horizontal pan and accumulated underneath. To avoid the problem, I have to periodically remove debris from the shaft bowl and make sure the pan pushed all the way down. To reduce the debris, I made a simple cover for the bread pan by cutting an old aluminum baking dish. I always remove the cover after the kneading cycle to prevent the rising dough from reaching the bottom of the cover. Hope this helps. Wendy
Feb 22, 2009 | Breadman TR2200C Ultimate Bread Maker
Kneading blade stays in bread after cooking.
This sometimes happens. I have a Panasonic.
When you place contents in pan with some machines it is important to place contents
in a particular order. I should try to keep contents away from the kneading blade as you place them.
Another thing that might possibly help is to put a litter olive oil around the blade before adding ingredients.
Hope that this helps
Alleillia
Dec 02, 2008 | Breadman Kitchen Appliances - Others
Bread machine pan and kneading blade
here's the manual if you need it http://www.bread-maker.net/Bread-maker-reviews/Product%20Manuals/Betty-Crocker-BCF1690.pdf freefone for spares from manufacturer: 1-866-819-4335 hope this helps :)
Mar 06, 2007 | Betty Crocker BCF1690 Bread Maker
Kitchen Appliances - Others Logo
134 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
ellenskitche
Irene Tulloch
Marvin
Marvin
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
