Question about ZVOX ZBase 580
I can turn "on" my zvox 580 - ZVOX ZBase 580
I have a ZVOX 580 soundbar. Using the digital optic cable I have no sound. I have sound through RCA cables. Can you help?
They to check the menu of the TV is there is any option to activate the Digital out or is there is any setting which allow you make a selection between internal speaker or external speaker. if its there the make the setting as external speaker .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 15, 2016 | ZVOX ZBase 580
When turning on with universal remote, zvox screen says on, then off, I have to use zvox remote to turn on
Universal remotes only work when the correct code is entered into it. Some codes for the same make will work other models, but things are either missing or function differently. You need to find the correct code and try the functions using it. If everything is OK then it should be fine, if not try another code.
However the best remote for the job is the original that came with the equipment. Unless you have paid out a lot of money for a universal remote, you might never get the same responses as an original remote.
Oct 11, 2015 | ZVOX Z-Base 220 Speaker System - 35 W RMS...
I need setup code for my zvox sound bar for a Comcast remote?
I am the same boat. Just bought a bigger tv and my zvox doesNOT work now
Jan 26, 2015 | ZVOX 4002201 Audio Z-Base 220 Low-Profile...
ZVOX v-series 320 no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Dec 11, 2014 | Televison & Video
THE SOUND WORKS ON TV BUT THE REMOTE CONTROL DOES NOTHING.
Batteries could be bad, circuit board in the remote may be shot and try cleaning the infrared light on the remote and TV. If none of that works order a new remote or get an all in one, just make sure it has the programmable code for your TV
Dec 10, 2014 | ZVOX ZBase 580
Why do we have no sound when everything is corrected properly?
test the speaker with a known good source (cell phone, other stereo, etc) and see if that works. You have to pinpoint the reason why it's not working, could be power, could be signal source, could be connection quality, could be poor internal connection or solder/joint on a wire
Apr 27, 2014 | ZVOX ZBase 580
We lost power and now zvox volume very low
You could have fried something through a power surge or a connection came loose. Check all wiring and see if the speakers are connected, try different audio signals to see if that helps
Apr 10, 2014 | ZVOX ZBase 580
Zvox remote not working
Place the unit in learn mode: http://www.zvoxaudio.com/mas_assets/theme/zvoxnew/documents/ZVOX580_LearnRemote_Guide.pdf
Nov 08, 2013 | ZVOX ZBase 580
No sound
What type of cable are you using to connect your ZVOX system? Are you connecting your system directly to your TV? In order to solve your issue as quickly as possible I would encourage you to call our toll free number.
(866) 367-9869 We can troubleshoot over the phone and get you up and running in no time. Thanks.
- Joe
ZVOX Audio - Great Sound, Made Simple
www.zvoxaudio.com
866-367-9869
May 23, 2012 | ZVOX ZBase 580
What could be wrong if i have everything hooked up right i have it connected to the back of my directv box with audio coming out and going into input 1 on zvox box and is the blue light suppose to always...
1. Make sure it's connect to "Audio Out" on your DirecTV box.
2. Yes, the blue light should be on while unit is on an received a signal.
3. Check a second set of audio cables, just to be sure.
4. Toggle the Auto On/Off button on the ZVOX remote.
5. Make sure you've turned up the volume via the ZVOX remote.
If all these fail, contact us at zvoxaudio.com.
Tom
Jan 30, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
ZVOX ZBase 580 Logo
62 people viewed this question
Top ZVOX Televison & Video Experts
Electro Med Services...
Are you a ZVOX Televison and Video Expert? Answer questions, earn points and help others
