Question about Dell C1760nw Color Printer
Clean sensor how can I clean the sensor
How do I clean the mass airflow sensor on my 99 Grand Am V6 SE
carefully remove it from the air tube and use a spray cleaner especially designed to clean the sensor any automotive store sarries it
How To Clean Mass Air Flow Sensor MAF How To Clean Mass Airflow Sensor In depth detailed version How to Clean Your MAF Sensor
Aug 27, 2016 | Cars & Trucks
Plis help me my copy canon ir 4570indicators show the paper has jammed(paper stuck)when it was d check repeatedly ,cut no paper stuck again but the indicator still appears ,is there a solution for me
  • First clean the sensors
  • If Problem persists change Pickup rubbers.
  • If problem Occurs replace the pickups
  • Check and clean the Pickup sensor
  • Then check and clean registration(Steel rod) sensor
  • Then check and clean Fixing unit sensor.
  • And finally check and Clean the Delivery sensor.
  • Don't use air blowers and Hard cleaners just use cotton and brush.
Jun 21, 2016 | Canon Office Equipment & Supplies
Bin full light
The sensor build limestone residue during operation and needs to be cleaned off. The bin sensors are typically located on either side of the freeze platens and can be removed to clean. Turn machine off and unplug. Reach in past the water trough and freeze platen and you will see the transmiter and receiver plugged into the side walls. Gentlely work sensor loose and work sensor wiring out hole until you can get to sensors. Clean the two sensor with a clean cloth and with vinegar until sensers are clean. Reinstall, and plug back in and start unit. Bin sensor light should be out and should start.
Aug 24, 2013 | Scotsman Refrigerators
Can the oxygen sensor be cleaned
The upper and heated O2 sensors should not be cleaned as depending on the cleaner, can destroy them anyway, and the right cleaner for the component can't clean them well enough. It's best to buy new if the ECU kicks out 02 sensor code errors.
Apr 08, 2013 | 1998 Lincoln Navigator
Do you do Nikon camera sensor cleaning?
No. FixYa only provides online support, and we can't clean your sensor online. Any good camera shop should be able to clean the sensor for you, and/or sell you a sensor cleaning kit.
Apr 26, 2011 | Nikon D3S Body only Digital Camera
My ford truck failed the smog test because bank 1 and 2 are to lean ( p0171 & p0174 )
possible solutions are, a dirty maf sensor. remove manifold air flow sensor and clean it with maf sensor cleaner. you can buy a can at any auto parts store to clean, take off and clean maf sensor, do not touch inside of sensor it is very fragil. when cleaning sensor be sure it is dry before installing it back on vehicle. also check for a vacuum hose leak downstream of maf sensor.make sure air filter is clean. this usually takes care of the problem. po171 and po174 are the same. you can use electrical cleaner to clean sensor also. also check for a dirty fuel filter and fuel pressure, if needbe.
Feb 11, 2010 | 1998 Ford Taurus
Ricoh 2045 error code SC350
It can be dirty ID sensor it retires the image unit and it cleans it… This happens when mylar of the cleaning unit is damaged…
Dec 04, 2009 | Ricoh Aficio 450 Copier
Have error code sc457 on copier, have received detailed instructions on how to fix it, but I need to know how to open it?
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-012)
4. Replace the belt cleaning shift clutch.(Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O control board
The above information are taken from the service manual.
Good Luck!!!!!!!!!!!!!
Sep 20, 2009 | Office Equipment & Supplies
Clean sensor
Clean the sensor that is located inside this part.
Don't forget clean the LED in the middle and the Sensor in the sides.
Jul 01, 2008 | HP LaserJet 9500n Printer
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
the image
transfer belt’s
cleaning unit
section touches the
signal remains LOW.
remains HIGH.
• Dirty Sensor
• Defective sensor
shift clutch
• Defective drum
motor
board
board
belt unit.
H.P. sensor.
012)
motor.
[Signal Check]
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Dell C1760nw Color Printer Logo
29 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
