Question about Sony VAIO Wireless Keyboard Kit (NEWITEM34666976)
Sony vaio wireless keyboard is locked, can not type. a symbol of a lock is showing on the mini screen that has a "1" in it. Please help.
    President:
  • 1,623 Answers
Hello Vince...don't you just hate when that happens...it drives me crazy...Try this trick i learned...maybe it will work for you too.
Power down the lappy...remove the power supply. Hold the power on button down for a good 60 seconds. Reinstall power supply and boot up. I know this will work on a Dell..HP and Acer laptop....maybe we can add Sony to the list. If it dosen't work...i have a tech. manual i can dig out and we can try again.
Good luck...i hope this helps
Posted on May 18, 2009
How do you remove the keyboard on a Sony Vaio laptop PCG-7192L
Let's see if this helps Tom,
1) http://laptoppartstore.weebly.com/replace--remove-sony-vaio-vgn-nw-keyboard.html
2) http://www.youtube.com/watch?v=8BEcX_0KYIE
The Keyboard Cable STAYS attached to the Keyboard.
It disconnects FROM the motherboard's connector.
The Keyboard Cable has NO connector on the end. It is a FFC.
Flat Flex Cable.
One example of a Flat Flex Cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The flat metal terminal bars MUST be aligned back in the SAME position, as they were originally.
For this reason you may wish to take a Sharpee marker, and make a mark on one side of the cable.
Then make a matching mark on the same side of the motherboard connector, BEFORE you remove the cable.
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is composed of two pieces, but does NOT come completely apart!
The bottom part is larger, rectangular shaped, and is stationary to the motherboard.
It is the BODY.
The upper part is smaller, rectangular shaped, and is movable.
It is the Locking Bar.
ACCORDING to the video the Locking Bar is the Slide/Wedge type.
DO NOT use a metal tool as shown. One slip, and you can damage the motherboard! Geez!
Use your Fingernails, or Thumbnails.
The Locking Bar slides up. Up towards the LCD screen, or away from the Body.
It ONLY moves about 2mm. That is a little larger than 1/16th of an Inch.
IF, the Locking Bar is broken, or the Body, you are looking at
-> MOTHERBOARD REPLACEMENT!!
Hence why I am being so detailed.
More detail on unlocking this type of motherboard ZIF connector,
A) Locked position;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-11.jpg
B) Unlocked position;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-12.jpg
There is another style of Locking Bar used, however.
The Locking Bar flips up to a 90 degree position, or also can be stated as Straight Up.
Just to make sure I'm going to include info for it too;
A) Locked position
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 28, 2012 | Sony VGN Computers & Internet
Keyboard is locked
what is the response shown in screen?
Jul 10, 2012 | Sony VAIO VGN-TX650P/B' Notebook PC
How to unlock my sony keyboard vgp-wkb5fr
Accidentally locking your Vaio keyboard can cause typed letters and/or numbers to appear on the screen very slowly, or not at all. The locking function can occur if a user holds down the shift key for more than eight seconds. This feature can be unlocked through the computer's Microsoft Accessibility Options.
1. Click "Start," "Control Panel," "Ease of Access" and "Ease of Access Center."
2. Click "Make the keyboard easier to use." A new window will appear.
3. Remove the check-marks next to "Turn on Mouse Keys," "Turn on "Stick Keys" and "Turn on Filter Keys." This unlocks your keyboard.
4. Click "Apply" to save changes, then "OK" to exit the window.
if you think i misunderstands your problem or you have any other problem you can post again
Sep 01, 2011 | Sony VAIO VGP-WKB1 Keyboard
Please help. The 789uiopjkl;m./ keys have keypad numerals on the front bevel. when I try to type "uio" for example I get "456" and "jkl" gives me "123". To get the...
The number lock feature is enabled. You should see an indicator for the Num Lock (lit when on) that is next to the Caps Lock indicator.
You should be able to disable the lock by pressing Fn and Num Lock together on the keyboard. (On some Sony Vaio keyboards, type CTRL+ALT+NumLock or Shift+NumLock.) The number lock should be at the top of the keyboard near the F1-F12 keys. Sometimes the key is shared with the Scroll Lock function (otherwise it will be nearby). It's really easy for the Number lock to be enabled on some Sony keyboards; just some dirt between the keys can enable it when you didn't turn it on intentionally.
I hope this helps.
(I don't have the VGP-WKB1 wireless Sony keyboard and can't find a good picture of it to find the Num Lock key for this model.)
Jul 08, 2011 | Sony VAIO VGP-WKB1 Keyboard
Hi, my sony vaio keyboard has stopped working. It is Sony Vaio vpcec4c5e... Brand new,.. I tried to follow the tip with hardware wizard but I can't see an option to reinstall keyboard... please help
usually to check if its working try to check if therea light on the keyboard
press capslock or NUm lock
if no go
Fn and F11
or FN and F6
in case nothing happens
Fn+ Numlock
ou also need to close the on screen keyboard ( if you open it )
hope it help thanks
May 22, 2011 | Sony VAIO VGP-WKB1 Keyboard
Sony vaio keyboard not entering the right keys. when I type the wrong characters are entered on the screen. I have tried rebooting the laptio twice, and this did not fix the problem. I also tried...
Check windows language settings in control panel - language and region. You should have English US by default.
NUM LOCK key should be off on the keyboard
Mar 17, 2011 | Sony VAIO VGP-WKB1 Keyboard
I have sony wireless keyboard that is locked,i cant type
remove the batteries from the keyboard and replace with new ones then reset the pc all shoould be well
hope this helps
Jan 05, 2009 | Sony VAIO Wireless Keyboard Kit...
MY CAPS LOCK IS STUCK, AND WILLNOT GO BACK TO REGULAR
Just had this happen on a K800 wireless keyboard. Went into keyboard settings and *enabled* the caps lock key, turned off caps lock, then *disabled* the caps lock key again. Hope it helps
Jun 21, 2008 | Logitech LX 300 Keyboard/Mouse
Sony VAIO Wireless Keyboard Kit (NEWITEM34666976) Logo
746 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
