Question about GE Refrigerators
Ge model ptc22mbmarbb
Freezer not staying cold
  • 3 Answers
SOURCE: GE model TFX24FA side by side
If solution #1 fixes the problem, but it happens again, then check to see if you have water leaking from the ice maker area. I had a similar problem with my same model, and found that the ice maker water fill tube was leaking where connects to the connector in the back wall of the freezer. Water was leaking onto the freezer coils, causing it to go into defrost for long periods and both the freezer and fridge would warm up.
Getting to the fill tube is not an easy job. If you just pull it out without disassembling the fan compartment, you will probably not be able to get it back in.
You will likely want to move your food, unplug the fridge and thaw it out. Disassembling the top compartment on the inside of the back wall of the freezer is a tedious and time consuming task. After that I was able to just pull the tube out and turn it around and push it back in for a snug fit. You might consider using a sealer.
Posted on Apr 03, 2009
hiltonjug
  • 612 Answers
SOURCE: GE Refrigerator-Freezer side works fine/Refrigerator side not ok
You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
Please rate solution and make it worth the while to summit solutions. Thanks
Posted on Aug 28, 2009
woodchuck789
  • 4070 Answers
SOURCE: my GE fridge won't stay cold. The freezer up top
How to check parts
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Sep 07, 2009
iwillfixforu
  • 619 Answers
SOURCE: GE fridge/freezer on but no cold air
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Posted on Mar 07, 2010
heatman101
  • 43501 Answers
SOURCE: GE Hotpoint Top-Freezer model - freezer works but
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 01, 2010
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
I have a GE Model GSS22SGRF refrigerator. The freezer is cold but the freezer isn't staying cold. Any suggestions?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 23, 2011 | GE Refrigerators
The refridgerator party not staying cold... Freezer part is staying cold
Look into back of freezer and see if a layer of frost is building on rear panel. If yes unplug and manually defrost until you can get back with me with the model number. What you said is the first symptos of defrost not taking place. Look around door frame for the model and I will be back later with part numbers. Thanks, Sea Breeze
Mar 19, 2010 | GE Profile Arctica Stainless Steel Top...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
New french door GE fridge that won't stay cold
If " new " is less than 1 year , you will need to call GE factory service , for a warranty repair . If any one else works on it , this will void your complete warranty , and they will charge you for a service call + parts + labor .
Nov 13, 2009 | GE Refrigerators
Aug 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Jan 05, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
