I also say no to recovery,(but I do want to recover),but it still keeps me on the page.
SOURCE: Brand new Archos 101 8
Looks like you're sending back another one!
Don't muck with it, you could void the warranty!
SOURCE: I reformat my archos 101
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
20.3.1. To enter into the Recovery screen - Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual.option to another, use the volume buttons. To select an option, press the ON/OFF button. Go to this web page to see the latest on-line version of this manual.
20.3.2. Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration: Select this, set your device down, start the calibration, and don't touch it. It will re-calibrate the screen. After the calibration is complete, select No to leave the recovery screen.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased.
HOPE IT HELPS AND GOD BLESS!!!
LOL, ok, Reformat does just that (Delete All Files). Unless you have them backed up someplace outside of the computer, they are history.
Format and Recovery deletes everything. Recovery will set your system back to the time you first purchased it. But your personal files will be gone.
System Restore on the other hand does not delete anything. It allows you to restore your system back to a particular date and time. Your documents, music, pictures, videos, data and programs will not be deleted. You might have to reinstall programs that you installed after the date and time you selected.
every time i turn on my tablet it pop up archos A101IT Recovery.would u like to recover your system.no update firmwear.repair system.format system
