Question about Zenith C27A24T 27" TV
Can not getc channel 5 or 6.
I can not get channel 5 or 6.
  • markas2 May 18, 2009
    I get every other channel but not 5 and 6 Ive tried the menu thinking I need to change something but I cant find anything.
  • fougzki May 11, 2010
    Try autoscan or autosearch in your menu.
    Sergeant:
    Champion:
  • 255 Answers
Try manual fine tuning it.
Posted on May 18, 2009
Hi, my problem is only the front 2 speakers work i have tried all the speakers in the front 2 connections of the unit & all speakers are working but none when in the rear, center, & sub woofer unit...
Without knowing which receiver etc you have... make sure your "mode" is set to 5 channel, Dolby Pro or similar. And even then, make sure your source is 5 channel. What are you using for an input cable? It needs to be able to provide 5 channel. Standard RCA stereo type cords do not. You need either optical, "coax" or hdmi. Lastly do you actually have a 5 channel program? Many older movies, and standard cable boxes only output stereo, not 5 channel.
May 31, 2011 | Audio Players & Recorders
Unit is a 2 channel system. If connected to a 5 channel receiver can it function over the 5 speakers?
Most 5 channel receivers can simulate some kind of surround effect from a 2 channel signal, so the answer is most likely yes.
Jun 21, 2010 | Technics SL-PD887 5-Disc CD Changer
Hi, I am trying to turn the channel to 55 but when I hit 5, it goes to channel 5. How do i fix this?
Press the number 5 key two times quickly. If you pause too long between presses, the TV thinks you mean channel 5 and goes there!!
Nov 20, 2009 | RCA 257003 Remote Control
How do I retune my Samsung Syncmaster 19''LCD TV as channel 5 is not available.
Manually select channel 5 (NOT by pressing "channel-up" while viewing channel 4) and press the 'ADD/DELETE CHANNEL' button.
Or, run through the complete "automatic channel seek" first-time-setup function to "re-discover" all the available channels.
Oct 26, 2009 | Samsung 192MP SyncMaster 19" LCD Monitor
Cannot retune channel 5 on my tevion
You need to find a menu which has initial setup, setup channels or scan for channels in it. Without a manual it's difficult for me to guess where it is. Tevion Technical support is on 0161 975 0458
Oct 20, 2009 | Televison & Video
I had all 5 terrestrial channels on channels 1 to 5 on my television and Virgin channels on channel 6. I was sitting watching the television when all 5 channels stopped working and I am left with the...
I don,t where you live & therefore I don't know which transmitter you will be picking but this sounds as if your local transmitter has now stopped transmitting the analogue signal. You maybe aware from a lot of advertising that this form of signal will be getting turned off in different areas around the country so unless you have cable or a digi-box or a digital TV then you will not receive any signal. As you have the Virgin box you will still receive channels 1 to 5 on digital but not on analogue.
Oct 15, 2009 | Televison & Video
Trying to find Channel 5
Maybe your area doesn't recieve that channel. every area has diffrent channels. But usally Channel 5 works in all areas maybe the signal prob.
Sep 08, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
I have an Infinity 530a 5 channel amp. new
May be the problem is on the sound you are using is not a 5 channel coded sound or check in the menu´s of the amp if the rear channel´s have sufficient db output, check the connections, check if you amp. is not working only as simple stereo (menus also)
Hope this helps
Jun 24, 2009 | Infinity Car Audio & Video
I need an owners manual for the receiver
What channels on what satellite? You should always start with sat G1 channel 3 and rehit. This will map in all the channels the receiver is authorized to get from Motorola.Options 6 5 and the trip counter should go up by 5 and show ~ 4600 channels
After that you need to make sure you are good on the arc. Start with G-1 5 (analog) then go east about 20 counts to C3 channel 7 On both G1-5 and C3-7 you may need to adjust the skew to get the picture.
The same is true for digital channels like those on G3C like TNT, CNN, SPIKE etc.
Once you know you are on the satellite then adjust the skew.
Feb 22, 2009 | Arris DSR922
Dennon 3930 dvd player unable to play sacd in 5 channels only in stereo.will play dvd-a disc in 5 channels
For DENON DVD-3930: In "setup", HDMI sound settings have to be "2-channel". Then SACD 5-channel output is enabled.
Jul 14, 2008 | Denon DVD-3910 DVD Player
Zenith C27A24T 27" TV Logo
76 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
