Question about Uniden BC350C Base Scanner
Uniden bearcat BC355c Pr9-loc when i try to program it .
Everytime I goto program this I get a pro-9 loc . and no there is no switch to unlock anything on this type .
Mechanic688
  • 204 Answers
SOURCE: programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
Posted on Feb 12, 2008
SOURCE: programming error BCT8 Uniden
Hello.
Back to answer my own question.
I just found the problem. If you try to program one of these scanners (Uniden BCT8) and you keep getting a "pr9-loc" message every time you try to enter a frequency and "M-LOCK" is showing in the upper right corner of the display press and hold the M-Lock (E) key until it beeps twice and "M-LOCK" disappears from the display. You're now set to program.
Keith.
Posted on Dec 30, 2008
BillB-SA
  • 2761 Answers
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
Posted on Aug 16, 2009
BillB-SA
  • 2761 Answers
SOURCE: How do you program a Uniden Bearcat bc244CLT?
To program a known frequency into your scanner:
- With power ON, press MANUAL to stop scanning.
- Enter the number of the channel that you wish to program (01 - 30).
- Press MANUAL.
- Enter the frequency, including decimal point (for example, 156.065).
- Press E to enter/store the frequency into memory.
- Press MANUAL to advance to the next channel for programming.
For more information, you can download/print the manual for your scanner here:
http://www.uniden.com/pdf/BC244CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Posted on Apr 25, 2010
BillB-SA
  • 2761 Answers
SOURCE: Is there a video on
Sorry, but there is no such video that I know of. Besides that, your BC355C is not a programmable scanner in the standard sense, in that you cannot enter frequencies via the keyboard. You can, however, transfer a displayed frequency from the SCAN or SEARCH mode into the PRIVATE bank. Fairly simple instructions are in the factory manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC355Com.pdf
Bill B.
Listening in since the 60's
Posted on Jan 15, 2011
I tried to press bake which turns the oven on usually and got LOC in white letters instead of a temperature
Perhaps indicating the oven door is locked.
Look for an unlock button.
my Fridgaire oven has a led to indicate door lock
Nov 13, 2016 | Ovens
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
Everytime i try to program the scanner i get a loc9 code ? How does it unlock ?
ok there is a loc switch on back of scanner turn the switch off this should help.
Jul 06, 2011 | Uniden BC350C Base Scanner
2003 audi a4 had dead battery, charged battery and now the key fob won't work and the security lights flash for about 5 min everytime I do anything to the car. why ?
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative. Key batteries replaced.
How - early models
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should operate normally after approximately 1 minute. If not, carry out programming procedure.
How - late models
If vehicle locked, manually unlock driver's door using key. Press key unlock button once. Switch ignition ON and OFF. Remove key from ignition switch. Press key lock or unlock button once. System should now operate correctly.
Apr 12, 2010 | 2003 Audi A4 Cabriolet
Kb will not allow me to type my password
use on screen kb and see if it works...
Sep 15, 2009 | HTC Touch Pro Smartphone
Lock feature
LOC on is a lock out feature to prevent kids from playing with the stove. press 9 and 0 for 3 seconds and the loc will go off.
Sep 21, 2008 | LG Kitchen Series 30" Self-Cleaning...
M3plugin.dll
You have left over pieces of a spyware and/or adware program. Here is how to go about removing them:
1) Goto 'Control Panel' then to 'Add/Remove Programs'
2) Locate 'My Web Search' Select 'Change/Remove' and uninstall it.
3) Also look around for other programs associated 'FunWebProducts' like:
My Web Search
My Speedbar
Search Assistant - My Way
4) Once you have cleared the out of your program's list, proceed to your C drive.
5) Goto Program Files
6) Locate and delete the following folders;
FunWebProducts
MyWebSearch
7) Finally Goto Start>Run
8) Type 'msconfig' and press OK.
9) Once the msconfig window pops up select the Tab labeled "Startup"
10) Sift through the startup items look for anything pertaining to either FunWebProducts and/or My Web Search
11) Once found uncheck all of them(FWP/MWS items).
This should fix your start up issues. I would also advise you to Get Spybot-Search&Destroy From here. This will keep you from getting nasty programs like this again.
Hope that helps. If you have any questions lemme know.
Sep 16, 2008 | HP Pavilion dv6000z Notebook
Locked Keyboard
Goto control panel - keyboard. See if U can unlock it from there. Else goto control panel- system and uninstall keyboard, then "action" scan for changes and reinstall the keyboard. Normally the cd's that come with the keyboard have the programs to lock them out. Recommend... don't install the lockout program.
May 10, 2008 | E-Machines eMachines Desktop PC
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
To lock/unlock the controls:
Turn all surface burners off.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
To unlock the control, touch and hold the
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
All channels locked out pro-2055
I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs Contents You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc. To Lock out an ID while scanning, quickly press L/OUT while the ID is displayed. To Lock or Unlock an ID manually: 1. In Manual mode select any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the bank number (0-9), list number (0-4), and the list status (ON or OFF) on the 1st line, the ID# in the list (0-29) on the 2nd line, the ID on the 3rd line, and bank tag on the 4th line (if programmed). 3. Press TRUNK (each time) to select the ID list (0-4). 4. Select the ID# (0-29) by pressing up.jpg or dn.jpg (or press and hold; faster) then press L/OUT to lock or unlock the ID. An L will appear to the right of the ID# if the ID is locked out. 5. Press MAN to exit programming. To Unlock IDs in a bank: 1. In Manual mode select any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the ID list. 3. Press FUNC then L/OUT (each time) to view the locked IDs. Press L/OUT to unlock the ID. The next locked out ID will appear. 4. Press MAN to exit programming. Note: You cannot unlock all IDs at one time.
Nov 18, 2007 | Radio Shack Pro-2055 Base Scanner
Uniden BC350C Base Scanner Logo
364 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
