Question about Riso RZ390 Duplicator
RZ390 Risograph has light for ''CHECK SETTINGS'' Will not do anything! Also, does d-01-528 mean anything to anyone? Thanks
Just had the same thing happen. The ink cartridge was not completely in the lock position. Once I remove the ink, reinserted it and locked it, everything was back to normal.
Posted on Sep 11, 2009
  • 3 Answers
I'm sure I'm too late to help here, but for future reference D01-528 is "print drum safety switch is off" according to my manual. So the above solutions should do the trick. Every error starting with D01 referrs to "print drum not set."
Posted on Jun 07, 2010
  • 81 Answers
Try pushing the drum in a little to make sure it is in all the way.. if it is.. use a pencil and put it into the hole at the bottom of the drum until the pencil hits something in the back.. then pull the drum out... and try to reset it again.
Posted on Jul 07, 2009
Error A-01-211. Master roll not feeding properly.
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
OR replace it
Feb 22, 2013 | Riso RZ220 Duplicator
I have a Risograph RZ390ui. About a week ago, with my green drum installed, it began telling me to replace the ink cartridge, even though it wasnt empty. Now I cannot get that drum to work. Now, the same...
It is possible the ink with in the tube has become unprimed, example not push up to the exit point so its drawing air and never gets caught up before the error occurs. Be careful by pushing plunger inside tube due to the ink becoming "separated" from the oil and be to "liquid" for the ink pump to do its job..If it pours out like wine its to old sry.Should be as thick as toothpaste.
Sep 14, 2011 | Riso RZ390 Duplicator
Need instructions for changing out pressure roller on risograph rz390
usally you do not have to replace the pressure roller until your machine goes over 2mil. copies. sometimes it does need to be cleaned. you can clean it by scraping the pressure roller with scissors to remove the built up ink. to remove the pressure roller.1. Remove the drum2. if you look the pressure roller is held in by 1 screw on the frame of the machine. there is a hole in the frame to put a Philips (+) head screw driver through and remove 1 screw. BE CAREFUL NOT TO DROP THE SCREW!.3. gently push the pressure roller to the rear of the machine slightly then lift it up and pull towards you.
to reinsert the pressure roller line it up with the cutouts where it was removed the pull it towards you to secure it. then screw it back in.
PRECAUTIONS FOR REASSEMBLY make sure the pressure roller is well seated on both ends of its holders (front and back) and that it spins freely. if the drum does not go back in easly something is wrong.
Jun 25, 2011 | Riso RZ390 Duplicator
Error code A-06-403 on the Riso RZ390 - what does it mean?
A06-403 from the manual: either the upper or lower safety switch of the paper feed tray is off. Unplug/replug or replace.
Aug 26, 2010 | Riso RZ390 Duplicator
Error code p-12 316
Error P12-316 means:
Type: P12 - Master-disposal-section motor lock. Point: 316 - Master-compression-motor encoder sensor count did not change within 10 milliseconds after the master compression motor activated.
Hints: Check mentioned sensor. Check mentioned motor.
Aug 24, 2010 | Riso RZ390 Duplicator
Risograph RA4050 diplaying error code E11, anyone know what that means? Has recently been putting masters on the drum crooked and making grinding noise.
E11 is the pressure control motor encoder has nothing to do with the master problem it is most likely out of time. (grinding noise)
May 03, 2010 | Riso RZ220 Duplicator
Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Mar 11, 2009 | Riso Office Equipment & Supplies
Code d--13, ---9 risograph rz220
Check out copytechnet.com. Its a free service that covers copiers only. You can get in touch with a Risograph technician to give you the answer.
Oct 08, 2008 | Office Equipment & Supplies
Risograph 5800 repair
This is a cutter moter lock. you would have to replace the cutter unit.
Nov 10, 2007 | Office Equipment & Supplies
487 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
