Question about Crosley Refrigerators
Freezer seal Crosley Shelvador WCF15/F1 - Crosley Refrigerators
3 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Freezer, water problem
you have a frozen defrost drain, first of all defrost all of the ice out of the drain pan behind the grate, once the ice is gone you'll see a drain hole that goes thru the floor of the refrig. you need to flush some hot water thru this drain.
I use a big syringe filled with hot water to do this it will force any sludge build up out of the drain tube into the drain pan.
kind of an easy fix even if you aint 10=)
Posted on Dec 21, 2007
  • 1073 Answers
SOURCE: refrigerant pressures
normal 3 lbs on low side
Posted on May 28, 2008
I have a crosley shelvador fridge. the original power cord melted. i replaced the cord and all the wiring...not operating anymore. i have looked everywhere for the model and serial # but cant find it.
Why did the cord melt has to be a serious electrical issue like a frozen refrigerant pump motor, that means the fridge is done and should be replaced. If you wan to repair it contact a local appliance repair shop that sells used/rebuild fridges and has scraped parts, you may be able to find used parts for it.
Feb 14, 2017 | Crosley Refrigerators
How much is a door handle for a Crosley Shelvador 1952 model?
The only place I have ever seen that refrig is on the TV show "American Restorations" The are located in Las Vegas. Worth a try.
Dec 09, 2014 | Westinghouse Refrigerators
How muc`h is a door handle for a Crosley Shelvador 1952 model?
The one shown in the link below is $20.90. However, you will need your exact model number to be sure it's the right one.
Crosley Refrigerator Handle 218428101
Dec 09, 2014 | Crosley Refrigerators
How can I adjust an upright freezer door ?
Hello there,
It is always the feet and their adjustment and floor must be level
From the user guide it says
;The freezer must have all bottom corners resting firmly on
a solid floor. The floor must be strong enough to support
a fully loaded freezer.
NOTE:It is VERY MPORTANT for your freezer to be level in order to function properly. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems.
To level Upright Models:
After discarding crating screws and wood base, use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, half a bubble higher, so that the door closes easily when left halfway open. ;
User guide here
http://crosley.com/assets/product/1707/useCareGuide.pdf
Sep 24, 2014 | Crosley CFUM21LW 20.6 cu. ft. Upright...
Apartment size washer dryer. I have the chance to
Formed in 1976 in Winston-Salem, NC, the Crosley Corporation consists of a group of independently owned distributors who resurrected the Crosley trade name and introduced a line of refrigerators, freezers, ranges, dishwashers, air conditioners, and other appliances. We carried the heritage of such features as "Shelvador" and "Conservator" that were marketed for decades.
Sep 27, 2013 | Crosley Dryers
Crosley WCF16/W3 freezer
Insure you are getting good airflow. Check to see if t'stat is set right. Is it freezing at all. If not, you may be low on freon. There may be a small leak in the line. Are your door gaskets properly secure and seal well. If unit is 10-12 years or older, then consider replacing. This may be the beginning of the end.
Feb 14, 2013 | Crosley CFUM21LW Upright Freezer
Defrosted a Crosley freezer, have water draining from door
ITS RARE BUT NOT UNUSUAL,its only condensate from the surrounding room collecting inside a cold door frame,if you dont defrost it at least twice a year,you will loose efficiency.
Jul 05, 2010 | Freezers
Dec 20, 2007 | Refrigerators
Refrigerators Logo
55 people viewed this question
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
fta777
ray gallant
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
