Question about Water Heaters
Taco 671 2
My zone valves are very slow to open. They are Taco 671-2 model. I can turn up a thermostate and it could take up to an hour before any thing happens. The pipes are cold and there is no water circulating. This only seems to happen when it is very cold outside or if we have a fire in our fire place.
  • 2692 Answers
SOURCE: Hot Water Overflow
Do you have an expansion tank tank  in the line leading into water heater? If not what is happening is that the water is no longer allowed to go back into the city supply.  You said that you had turned it off while you left so the water heats up and has no place to go so the preasure/ temperature P/T valve  opens and lets out the excess water from the expanded supply (heater water) that has no where else to go. It used to be that the extra expanded water just backed up into the supply pipe and back into the main. That is no longer possible in most places by the  National Plumbing code.    The answer may be to install the expansion tank into the incoming line. You can see then now at  all hardware stores where water heaters are sold.
Posted on Jan 04, 2009
mrgrzz
  • 88 Answers
SOURCE: no water from hot water faucet
thanks for your question, sounds to me like you have a frozen line, I used to live in Northern, MN on a well, and had alot of time un-thawing water lines, yes it is continuous flow, sorry for having to say this but you need to immediately start tracing your hot water lines and see if you have any leaks, bulges, or ice forming on the line, tap the line with a screwdriver to hear the difference in sound when you find the frozen section, here is the tricky part, if its (pecks line, plastic) then you need to call a plumber, if copper, you can use a torch to un thaw the line, but use extream caution when doing this as many people has accidentally started fires, my best advise is to call a plumber, hope that helped, please get back to us and let us know what you find, thanks again, mr.grzz
Posted on Jan 21, 2009
  • 234 Answers
SOURCE: wiring a smart control to a taco sr504 to a honeywell L7248.
Set tempture up some so the water will be hoter.
Posted on Mar 18, 2009
miket756
  • 2702 Answers
SOURCE: Cold water suddenly shuts off during shower.
sounds like you may have "air" in the pipes and that bang has slamed the water reg valve shut hard
Posted on Mar 28, 2010
heatman101
  • 43501 Answers
SOURCE: My upstairs air handler is
You have a problem with your fill valve or pressure reducing valve...it is not uncommon for these valves to plug up or fail to work right.... this valve's job is to maintain 12 psi in your system.
If you do not have enough pressure it will not push the water to the upstairs air handler...
You also will then need to get the air out of the pipes for the pump to work right after getting the pressure problem fixed...
Here is a tip that will help you with that also...
Valve Pressure Reducing or Pressure Reducing Valve
heatman101
Posted on Nov 06, 2010
Taco circulator
Is this for a hot water system? If it is, u might have air in the system.
Mar 04, 2014 | Taco 007-F5-5 Cartridge Circulator Pump,...
Need to replace a taco zone valve head
Should be able to swap them., or get a qualified tech. to do it.
Mar 04, 2014 | Taco 3/4" Gold Series Zone Valve 571
I have a hot water boiler with 3 zone valves and 2 circulation pumps. I see no relays wired to pumps. Pumps run constantly
Sounds like a lot of unknowns from your article. Here are some basic checks
- if they are the honeywell zone valves and you try to open them and get resistance than 9/10 times the t-stat is not calling for heat and the valve should be closed
-if stat is calling and wants heat zone valve lever should be free of resistance when moving it
- 15-20 psi is a little high but could be normal based on the size of your place and the temperature you are reading these pressures at
-with the pumps always running seems to me that the pumps are hard wired to a constant electrical source, if you want optimal control install a taco zone controller
May 21, 2017 | Water Heaters
Taco 007 not working
If the motor is getting warm I would suggest replacing the Cartridge assuming all the air is out.
Jan 23, 2014 | Taco Cartirdige Circulator Model 007
Taco pump noisy whine
Take apart and clean with white vinegar.
This will remove scale and build up causing noise in line.
Nov 27, 2012 | Taco 007-F5 Outdoor Wood Furnace...
3rd yaco 006 in 3 years hot h20to hot
Taco circ. should be bronze in color for domestic applications. If it is green, it's wrong. Average temp for hot water should be 120 degrees. Overheating of circulator may be the cause of premature failure.
Mar 28, 2009 | Water Heaters
Wiring a smart control to a taco sr504 to a honeywell L7248.
Mar 18, 2009 | Water Heaters
Water Heaters Logo
62 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
