Question about Maisto Rock-crawler Remote Control 4wd Truck
STEERING DOES NOT WORK - Maisto Rock-crawler Remote Control 4wd Truck
My 2001 Pontiac Astez power steering is not working put new rack and pinon &power steering pump and both fluid hoses
If all is assembled correctly and the system is bled by working the steering from lock-to-lock several times with the engine running and topping up the reservoir as required, the power steering should work. A pressure test would prove whether the pump is working correctly.
On later CAN-bus controlled cars the electronics might need telling the steering has been repaired or replaced before it will work satisfactorily.
Jun 08, 2016 | Pontiac Cars & Trucks
Electric power steering works intermitantly
'electric power steering'?
Power steering usually works by oil pumped by a manual pump driven from the serpentine belt. Your sounds like the Power Steering oil needs topping up. Make sure you use the correct ATF fluid as there are different types. It will be written on the cap of the Power Steering reservoir.
Apr 14, 2016 | Cars & Trucks
MY LOW BEAM LIGHTS, BREAK LIGHTS AND RADIO SOUND CONTROL ON STEERING WHEEL, ALL STOPPED WOKING
Steering wheel radio controls and horn not working - Jeep Wrangler ...
www.wranglerforum.com/.../steering-wheel-radio-controls-and-horn-not...
Sep 22, 2014 - 12 posts - ‎6 authors
... 2Dr sport and my step/reset buttons, radio control and horn all stopped working. ... Also the lights behind the step/reset and cruise control went out, but the ... Soundslike a bad clock spring ribbon cable in the steering wheel. steering wheel buttons not working
Jun 14, 2012
Steering wheel audio controls
Mar 5, 2011
More results from www.wranglerforum.com
Nov 23, 2015 | Cars & Trucks
Horn and steering wheel controls not working.
    images for 2004 Suzuki Forenza no controls on
    Suzuki Steering Wheels and Horns ' eBay
    www.ebay.com/sch/Suzuki-Steering-Wheels-and-Horns/.../i.html
    eBayFind great deals on eBay for Suzuki Steering Wheels and Horns in Steering ... 2004Suzuki Aerio Grey and Black Steering Wheel with Airbag OEM 2003 ... 04 05 06 07 08SUZUKI FORENZA- Steering Column, Black with Key, NO AIRBAG ... 2006 Suzuki Aerio Gray Leather Steering Wheel with Controls OEM 05 06 07 Nice.
Sep 25, 2015 | 2004 Suzuki Forenza
Intermitting power steering
In relation to these problem there is solved help link,i suggest you to go click the link below and troubleshoot the problem:-----
POWER STEERING TROUBLESHOOTING, STEERING SQUEAKS, POWER STEERING FLUID LEAKS, FAULTY POWER STEERING PUMP, POWER STEERING NOT WORKING, POWER STEERING BELT,
http://alltypesofpartsreplacing.blogspot.com/2012/12/power-steering-troubleshooting-steering.html
These will help.
Thanks.
Dec 12, 2012 | 2008 Kia Sportage 2.0
Power steering does not work turning right. what
Hi Ben,
Air in the line. Be sure the steering fluid level is up to the fill line.
Turn the wheel to the stops both ways a couple times.
Check the level again.
Repeat until the level remains static,
Best regards
Mike
Apr 30, 2010 | 2003 GMC Sierra 1500
Power steering stopped working but has steering
can you look and see if the belt that turns the power steering pump broke or is slipping or quit pumping or if the rack and pinion is conking out. it is 1 or the other . pump and a rack & pinion they both have to work to get power steering.
Nov 19, 2009 | 2003 BMW 325
Power Steering
have the power steering steering self tested for a defective steering assist sensor on the steering column
Sep 09, 2009 | 2006 Saturn ION
Steering Wheel Control
I installed a body lift and now none of my steering wheel controls dont work any ideas
May 07, 2009 | 2005 Nissan Altima
Steering is hard
the steering rack and pinion unit is failing, that is why you are getting the symptoms u have.
Apr 28, 2009 | 1997 Plymouth Breeze
Maisto Rock-crawler Remote Control 4wd Truck Logo
48 people viewed this question
Top Maisto Toys Experts
ray gallant
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Maisto Toy Expert? Answer questions, earn points and help others
