Question about Body Sculpture Br1900 Twin Hydraulic Rower
New bearing wheels under seat for body sculpture br1900
I need new bearings for seat of body sculpture rowing machine br 3050
Remove the bearings and take them to your local Industrial Supply retailer, they should be able to cross reference and get you the ones you need.
Feb 24, 2015 | Exercise & Fitness
Body sculpture treadmill runs for 6 seconds then stops
1( LUBE the deck belt, this happen because the lack of maintenance
2( LUBE the rollers bearing too.
3( test the input voltage motor, if there are the motor need repair.see my personal TIPS
4( test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Oct 07, 2012 | Body Sculpture Bt3152 Motorised Treadmill
How do you remove the Hub and Rotor on a 97' F250 with Auto 4 wheel drive? I can not get the rotor to come off. I know that the hub must come with it. However, I am not sure what I have not removed in...
Section 05-03C: Wheel Hubs and Bearings, Front Wheels, 4-Wheel Drive 1997 F-250/350/Super Duty Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 05/17/2000 Locking Hubs, Manual
Item Part Number Description 1 3A329 Halfshaft 2 3C132 Rolling Diaphragm Seal (Axle) 3 3299 Integral Spacer Needle Bearing Seal 4 3123 Bearing, Caged Needle 5 3105 Front Wheel Spindle 6 1190 Wheel Hub Grease Seal 7 4221 Inner Wheel Bearing (with Bearing Cup 4222) 8 1102 Front Disc Brake Hub and Rotor 9 4221 Outer Wheel Bearing (with Bearing Cup 4222) 10 - Pin (Part of 1195) 11 1195 Inner Lock Nut 12 1198 Lockwasher 13 1197 Outer Lock Nut 14 - Steel Thrust Washer
(Part of 3B458) 15 - Plastic Thrust Washer
(Part of 3B458) 16 - Splined Thrust Washer
(Part of 3B458) 17 3B457 Snap Ring 18 1K105 Hub Body 19 - Lock Ring (Part of 1K106) 20 1K104 Cap 21 1K104 Capscrew A - While Rotating Front Disc Brake Hub and Rotor, Tighten Inner Lock Nut to 68 Nm (50 Lb-Ft) to Seat Bearings. Back Nut Off 90 Degrees (1/4 Turn). B - Tighten to 217-278 Nm (160-205 Lb-Ft) C - Tighten to 4-6 Nm
(35-53 Lb-In) Removal
  1. Separate cap assembly from hub body by removing the three Torx® head capscrews.
  1. Remove the lock ring seated in the groove of the front disc brake hub and rotor (1102).
  1. Remove the hub body assembly from the front disc brake hub and rotor. If the body is difficult to remove, install two capscrews and pull the body assembly out of the front disc brake hub and rotor.
Installation
  1. NOTE: Do not pack the hublock body assembly or cap with grease. Excessive grease can cause excessive dialing effort and hub failure.
    Follow removal procedure in reverse order.
  1. Tighten three Torx® head capscrews to 4-6 Nm (35-53 lb-in).
Oct 04, 2010 | 1997 Ford F250 SuperCab
Coaster wheels under the seat riding rough
I think you will have to replace the wheels. the clicking noise in the bearing in the wheels are failing. make sure to lithium grease the track the wheels ride on this protect the new wheels and make the machine move smoother
Oct 03, 2009 | Exercise & Fitness
Body sculpture BT2710 instructions
hi if you email body sculpture on sales@hi-markgroup.co.uk they will send you a free manual by pdf they are brilliant i know because i have used them for the same reason myself last week
Jules
Apr 08, 2009 | Exercise & Fitness
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Mar 31, 2009 | Exercise & Fitness
Body Sculpture Br1900 Twin Hydraulic Rower Logo
27 people viewed this question
Top Body Sculpture Exercise & Fitness Experts
Electro Med Services...
John
ray gallant
Are you a Body Sculpture Exercise and Fitnes Expert? Answer questions, earn points and help others
