Question about MSI FM2-A85XA-G43 Desktop Motherboard - AMD A85X Chipset - Socket FM2 ATX - 1 x Processor Support - 64 GB DDR3 SDRAM Maximum RAM - CrossFireX, Hybrid CrossFireX Support - Serial ATA/600 RAID Supported Controller - On-board Video Chipset - 2 x PCIe x16 Sl
Appears to have a network connection drop out
FM2-A85XA-G43 Desktop Motherboard mobo is constantly blinking the red light for the network status on the monitor and many times it say there is no network connected but then connect a second or so later. Modem isn't having any problem and not seeing this problem with any of the other computers and Ipad that uses this modem.
    New Friend:
  • 86 Answers
One way of fixing it is by getting a netword card if u you are pretty sure dat the problem is with you mobo LAN port... The NIC/LAN card is very cheap .....
Posted on Dec 27, 2013
Testimonial: "This MOBO is less than a month old. I want to determine if it is causing the problem so I can return it."
  • 624 Answers
SOURCE: Blinking Power LED ... no other action
Hi switchblade, Some of this will seem basic or even a rehash of what you?ve already done but please keep an open mind. The one thing I?ve learned over the years is never assume anything especially when things aren?t working like they?re supposed to. -The first thing I would do is to check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. It?s possible that whatever caused them to replace the motherboard could have been caused by a defective power supply or vice versa. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. -Try a more basic known good video card, a PCI if you have one. -Again whatever problem caused MSI to warranty replace your motherboard could have damaged your processor or memory. I would have expected a beep code but if you?ve gotten this far without resolving your problem we?re running out of possibilities. -If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Posted on Jan 08, 2007
aceltix
  • 119 Answers
SOURCE: MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Posted on Feb 08, 2008
mspcrepair
  • 169 Answers
SOURCE: MSI 7041 Motherboard problem?
RAM would be my next guess. If the board is bad, so could the RAM be as well. Try swapping some known good RAM and see what happens. Or, at the least (if you have more than one stick), remove all but one and try again. Repeat until all sticks have been tried by themselves - you could just have one RAM stick causing the problem.
However, usually even if you have one bad stick, your system will still post, just show less memory. On the off-chance that all sticks are bad, then you might have similar symptoms.
Sounds like a bad mobo to me :(
Scott
Posted on Oct 06, 2008
leecom72
  • 4806 Answers
SOURCE: MotherBoard won't power on (Could be LED placement issue)
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Good luck and thanks for using FixYa!!
Posted on May 21, 2009
  • 14 Answers
SOURCE: msi and axper motherboards not powering up
How are you testing these boards? Have you completely installed them into the chassis, hooked up all the wires, attached all the components, put in all the cards, processor, HDD, etc.? If not, then I don't know what you think it's going to do otherwise. These boards need to be handled as minimally as possible to make sure they do NOT receive any static charge build up to damage any sensitive components. When a mobo powers up it performs a POST (Power On Self Test) and this includes a complete check to make sure that all the components are attached. If not, it shouldn't do anything. If it can't past POST, then it won't go to the BIOS, and in modern boards, cooling fans are controlled either by the BIOS or even the OS to adjust for cooling power and fan size/sound. More than likely, if your fan is turning on initially, it's just current coarsing through the board. When you attach the 4 pin connector it's trying to power up the board completely and the fan's wont run until they're controllers tell them to.
Posted on Jun 09, 2009
Yellow light constantly flashes on all handsets
Yellow light constantly blinks on top of all the cordless phones
www.faqqq.com/.../yellow-light-constantly-blinks-on-top-of-all-the-cord...
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Panasonic KX-TGP550 Normal Status Lights
www.statuslights.com/panasonic/panasonic-kx-tgp550.html
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
Jan 16, 2016 | Panasonic KX-TG7641M KX TG7641M KXTG7641M...
How do I fix the Television that has a constantly blinking re status light and will not come on?
re-install the lamp door cover if you own a mitsubishi. they wont run without it.
Jan 28, 2015 | Televison & Video
H77MA-G43 defective
If you could provide additional information, i might be able to help you. But if your already convinced that the board is defective, and
depending on when you purchased the Motherboard, you can submit a RMA with MSI.
End User RMA Request Form
Apr 08, 2014 | Micro-Star MSI H77MA-G43 Desktop...
Red light on motherboard
check mobo manual and/or manufacturer support website for the exact meaning of this blinking light !!! Then proceed with faulty (or mismatched) component (mobo, cpu, mem ??? )
Feb 13, 2014 | Intel DQ57TM Executive Series Motherboard
Lost sound
Hi, I not an expert here but I willing share my advice...
1st thing 1st, check the driver of the sound adapter whether it is install accordingly... cause sometime driver might be the problem...
2nd, run diagnosis... run command dxdiag in run box from the start button... check if diagnosis is success or failed...
3rd, if you have sound card(USB or slot) try use it, to check whether your built-in sound(from m/board) might(could be) has malfunction...
I hope this help you to solve it...
Jan 26, 2014 | MSI FM2-A85XA-G43 Desktop Motherboard -...
2 short beep continue after 30second
AMI BIOS:
1 beep - System boot successfull
*1beep - Refresh failure - (NO VIDEO) memory refresh failure (bad memory)
2 beeps - Parity error - bad memory
As it is a Memory problem, the first thing to do is gently remove the memory chips (there maybe 2) and firmly re-insert them, to make sure there is a good contact.
If it still Beeps on re-Booting, then you need to go to a supplier to get them tested, or re-placed.
Source: http://forum-en.msi.com/
Author: Svet
Jan 22, 2014 | MSI FM2-A85XA-G43 Desktop Motherboard -...
Two shart beep
Irsadalam, i have just answered your question the 1st time you asked it. please look at it!
When I power on the desktop the power button LED turns to steady amber and the fans race constantly at high speed. The system does not seem to complete POST or boot into the O/S. I changed the CMOS Battery...
Can you check at the back of the computer to see what the diagnostic lights are indicating 4 led's (eg yygg - yellow yellow green green) - post the result and i may be able to provide a soltuion
Sep 24, 2013 | Intel K83v0 Dell Motherboard Inspiron 560...
Two Red lights blinking constantly. unable to
Epson -R 230 desktop printer. Two Red lights blinking constantly on the control panel (beside main switch). unable to print.
Oct 24, 2009 | Epson STYLUS R230 InkJet Photo Printer
Desktop turns off and a flashing red light appears
Sounds like you need to reseat the processor and heat sink, and use some good quality thermal paste.
If a reseat dosent do it, test the power supply, ocasionally they will be bad right out of the box, it is rare, but it happens.
Also check the MoBo connections, and make sure all fans are connected powered up and spinning, people often miss reconnecting something when swapping motherboards.
Hope this helps!!
Jim
Aug 06, 2009 | HP Compaq Business Desktop dc5750
MSI FM2-A85XA-G43 Desktop Motherboard - AMD A85X Chipset - Socket FM2 ATX - 1 x Processor Support - 64 GB DDR3 SDRAM Maximum RAM - CrossFireX, Hybrid CrossFireX Support - Serial ATA/600 RAID Supported Controller - On-board Video Chipset - 2 x PCIe x16 Sl Logo
59 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
