Question about Omnitech 12 Sheet Cross Cut Shredder
Red light shredder - Omnitech 12 Sheet Cross Cut Shredder
RED Light is on (left of the green light)
Reverse shredder and clean out as much paper shred as possible. Use some lube oil. Hairclipper oil and canola vegetable oil are good choices.
Aug 26, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
Shredder stops - red light off
Some shredders are great for thicker paper. If you put a thicker piece of card through, it should activate the switch located in the middle of the shred blades. The paper might be too light to push it forward. Also, if you click the feed catch beyond it's operating position, this can also stop the shredder with no lights.
Jan 25, 2014 | Intimus 280 Shredder
I have an Ativia 6000 shredder. The red light comes on and the shredder stops, after only shredding a few papers..why?
If place too many pages in the shredder the motor will be overworked and it will overheat and shut down until it has cooled down. Try shredding fewer pages at a time.
Jul 03, 2012 | Computers & Internet
Rexel RSS1627/RSX1227 Red light always on when
I have an Acco Rexel RSX 1227 shredder. Can you use any oil to oil the shredder or must it be a special oil
Aug 22, 2011 | Office Equipment & Supplies
Cuts out after 1 second & red light comes on
The red light typically means either something isn't installed right in the shredder head, or there's a paper jam. Did you recently take the shredder apart? If not, there's probably some jammed paper in there somewhere.
Jul 06, 2010 | Fellowes PS60-2 Shredder
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF1000MX Shredder
Red light on as well as green,what is the red light
The red LED can mean one of two things -- either the shredder head is not assembled correctly (did you take the shredder apart recently?) or there is a paper jam inside the machine. Sometimes the jammed paper is far down and hard to see.
Jan 30, 2010 | Fellowes PS60-2 Shredder
Shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Dec 07, 2007 | Fellowes Powershred 420 Shredder
Red light on with green light
This is more than likely a sensor issue. Fellowes Customer Service can advise you on a solution with a little more info than provided. 1-800-945-4545
Oct 16, 2007 | Fellowes PS70-2CD Shredder
Omnitech 12 Sheet Cross Cut Shredder Logo
209 people viewed this question
Top Omnitech Office Equipment & Supplies Experts
ray gallant
Are you an Omnitech Office Equipment and Supply Expert? Answer questions, earn points and help others
