Question about GAMEVIL Zenonia
Zenonia 5 crashes on startup
I just open the app and a black screen appears and then shuts off to the home screen. Version 1.1.5 and OS Android 4.2.2
How do I fix process com.android.settings?
Android Fix Process com android settings stopped unexpectedly Error
" experienced a problem with my Samsung Stratosphere where the Settings app would crash every time I plugged the device in. It would throw an error that said "Process com.android.settings stopped unexpectedly. Try again." The only option is to "Force Close" . This same error would appear whenever I went to Settings > USB settings. Fixing this problem was easy.
Since the settings app is ultimately the thing that's crashing here, it will need to be reset. That means you'll lose a few custom settings such as your wallpaper. Follow these steps to solve the problem.
1. Select Settings.
2. Choose Applications.
3. Select All.
4. Scroll down and select Settings.
5. Select Clear data.
Apr 25, 2015 | HTC EVO 4G Smartphone
HOW CAN IT BE FIXED? CAN IT BE DONE ONLINE?
Have you tried doing a factory restore? It will wipe all the information from your phone(contacts, downloaded apps, etc) most likely this well solve your problem it sounds like the android os is not booting properly or may have a system dependent service crashing on boot causing the system to hang. With the phone off press and hold the power button and the vol down button(might be volume up button) should get you into recovery mode where you can do a factory reset.
Apr 24, 2014 | Kyocera Event Black Smartphone AA€A Virgin...
Stackhash fd00 appcrash
Looks like a corrupted exe file try to solve it with scandisk and if it doesnt help try to reinstall the app.
Nov 28, 2013 | Computers & Internet
Primavera softawre not login
Problems: App Crash Problems usually happens when the computer overloads with to much data, or when certain system files become missing or broken. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer. dialog_warning.png Symptoms:App Crash Problems symptoms can include program lock-ups, slow PC performance, system freezes, blue screen, shutdown or startup problems, and installation errors.
Recommendation: To scan, diagnose and repair your computer, use the Free Download Advanced System Care from iobit.com
Nov 20, 2013 | Computers & Internet
Screen lock
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):
1. Unlock your Android device
2. Find the Applications menu and select "Settings"
3. Under the "PERSONAL" group, select " Security"
4. Under "SCREEN SECURITY" group, select "Screen Lock"
This will ask for the security pattern first.
5. The options for screen lock will appear, select "Slide" and you are done!
Hope this helps.
Nov 04, 2013 | Lenovo ThinkPad Computers & Internet
Samasung gt s5300 wont open
Try Samsung support via the website.
May 02, 2017 | Cell Phones
Root my Android mobile phone
So you want to root your Android phone and gain the root privilege over your device, right?
Here is the secure guide to unlock without voiding its manufacture warranty or any supported services.
Sep 11, 2012 | ClockworkMod Launcher
Please help, Main screen for Zenonia 3 was missing plugins
Reinstall the app. It should take care of it.
Aug 06, 2012 | GAMEVIL Zenonia
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Apr 03, 2012 | Tablets & eReaders
Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Aug 27, 2009 | Apple iPhone Smartphone
Video Game Consoles & Games Logo
206 people viewed this question
Top GAMEVIL Video Game Consoles & Games Experts
James Wishart
Are you a GAMEVIL Video Game Console and Game Expert? Answer questions, earn points and help others
