Question about Precor EFX 546i Elliptical Version 4
Ramp on my precor 456i won't move
It states "stuck key"
  • Precor Master
  • 914 Answers
Chances are there is a stuck key on the keypad. Normally the only way to correct this issue is by replacing the overlay and keypad. http://www.sportsmith.net/ Use your serial number to find the correct item for your version.
Posted on May 14, 2014
2 Suggested Answers
bwinton
  • 83 Answers
SOURCE: The ramp will not go up or down. It's states low
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Posted on Mar 19, 2010
On an incline higher than 5, there is a metal on metal sound as I press down my left foot. I removed the front panel but I can't tell if it's the lift mechanism or the ramp....
Is the ramp steel or aluminum? (steel is magnetic, aluminum is not) If steel, the ramp probably broke - if you tip it over, you may be able to see the tear in the metal. Replace the ramp.
Mar 14, 2014 | Precor EFX 5.17i Elliptical Fitness...
Precor 5.17i lift wobbly
INcline it all the way up and look underneath the ramp. Check where the ramp attaches to the main frame. If there are cracks in the bottom of the ramp, you need a new ramp, especially if you have a steel ramp as opposed to alumunum.
Mar 14, 2014 | Precor Exercise & Fitness
Key stuck error
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the starting point for the parts for this manufacturer. You will need to narrow your search according to the model and serial number of the machine.
Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH...
Jan 31, 2014 | Precor Exercise & Fitness
Ramp is stuck
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is commonly caused by a bad overlay/keypad. The only solution to resolve this issue is to replace the overlay/keypad.
Please use your model and serial number to find the correct replacement at the following link: Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH net
Dec 27, 2013 | Precor EFX 546i Elliptical Version 4
Noise while in use
First, check the ramp area. A ramp with worn groove marks can become quite noisy. It could also be coming from a bearing in one of your wheels. If the noise seems to be coming from the rear of the machine, attempt to lubricate the moving parts and the different connection points. Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
May 29, 2012 | Precor EFX 546i Elliptical Version 4
I have an efx 546i and when I try to use the incline the panel states: No ramp, low battery
Jan 03, 2010 | Precor EFX 546i Elliptical Version 4
The ramp will not go up or down. It's states low battery (546i precor)
Dec 29, 2009 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
187 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
