Question about kawasaki PVS-10921 Portable DVD Player
Battery on Matsui MAT PL700 dvd player wont hold charge
Where can I source a replacement rechargeable battery
2 Suggested Answers
  • 3 Answers
SOURCE: Need replacement battery
http://www.1800customersupport.com/products.aspx?type=pad&view=107&p=71&sc=5
that link will take you to buy a replacement for 28.00. It may seem like a lot but its worth it in the long run.
Posted on Mar 15, 2008
Can I use rechargeable batteries?
didnt specify device --rechargeable batteries are a power source like regular batteries but you can recharge them when they get low and not change them out and buy new --so unless their is a special warning on the product specifically stating no rechargeable batteries you can use them
Aug 30, 2016 | Audio Players & Recorders
Can I replace the battery in my Big Blue Party speaker?
Mike, all batteries usually can be replaced, you will have to dimantle speaker till you can remove battery which will have #s on it.
Order one on google or check out electronics shop like the source for replacement rechargeable battery.
Rechargeable Batteries
Battery Buyer Batterybuyer com
Mar 23, 2016 | Cars & Trucks
How do you open the Sylvania model no 72032 rechargeable flashlight to replace the battery and light bube?? Thanks
This is from the Sylvania site
  • Dimensions: 2.4" long x 1.7" diameter
  • Light Source: 0.4 watt non-replaceable LED
  • Internal Battery: Sealed Ni-MH 3.6V 110mAH rechargeable battery
This look like it is not replaceable - amazon sells them fairly cheaply
Oct 04, 2014 | Camping, Backpacking & Hiking
Doesn't recharge when plugged to a power source
Have you checked to make sure the battery is still good?
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Nov 14, 2013 | Computers & Internet
My pro 39 scanner loses memory after unplugged for 24 hrs..Question: is there a memory storage battery inside unit..
Here's a link to your radio's manual. Make sure the rechargeable batteries are able to accept a full charge. If they have been recharged more than a couple of hundred times, they may need to be replaced.
Pay attention to which jacks your are powering the radio through. The PWR and CHG jacks perform some similar, but very different functions.
The AC or DC adapter can be connected to the CHG jack when you wish listen to the radio (and recharge at the same time) ONLY when NiCad batteries are installed (or to simply recharge the NiCad batteries with the radio off). Recharging with the radio off will allow the batteries to recharge fastest (10 - 18 hrs).
As per the manual, you should not connect a power source to the CHG jack if using anything other than NiCad batteries in the radio, as they will heat up and could explode, instead connect to the PWR jack whenever using regular, non-rechargeable batteries.
Jul 26, 2012 | Radio Communications
How can i check if which need replacement my batt or my charger coz when i charge my batt the led lights on then after a while it turn of the led light then ill unplug it and plug it then still the same...
Power Source Li-ion Rechargeable Battery (LI-42B) Are you using the above battery?
Check the voltage to make sure it has enough as printed on the charger or the battery.
Alkaline rechargeables, or NiMH rechargeables, or other types of batteries don't have enough voltage or amperage as compared to Li-ion.
Jul 03, 2010 | Olympus FE-280 Digital Camera
My Garvin could not be recharged. I replaced the battery. I could use the GPs with the new battery. Once the battery needed to be recharged, I could no longer use the GPS. I plugged it into the wall socket...
The charge circuit has been damaged. It will need to be repaired or replaced. take it to your nearest Garmin dealer.
Please rate my help++++Thanks for using FIXYA
May 08, 2010 | GPS
The laptop only works plugged in to dc; because the battery doesn't keep the electric charge
This is a common problem when the battery is not "cycled" (allowed to discharge fully by using without the power supply and recharged). The batteries tend to short internally when this is the case, and must be replaced. Ebay is a fair source for low cost replacements, but take careful note of the specified condition (new,used,as-is,etc.), and make sure to run down the replacement and recharge it regularly to prevent the same problem from returning.
Feb 28, 2010 | Acer Aspire 3004WLCi Notebook
My solar lights will not stay on they will blink and go off.I live in Florida SUNSHINE most of time. These are from Home Depot and are Hampton Bay mfg.
... and they are how old???
In my experience, where I live to the North of you, where I work in a camping resort, where our seasonal campers make use of the same devices from the same supply and source), I have found the batteries in these devices are good for NO MORE than two seasons with little exception.
You might have other troubles, like the day-lite sensor is cloudy or being impacted by some other light source or the panels are cloudy and will not charge the battery fully. Read on please.
The way these things work, generally speaking, the solar panel part of your light actually recharges a rechargable battery in the battery pack. These batteries take a beating - fully recharging and fully discharging EVERY DAY. You can probably replace these batteries with new RECHARGABLE batteries to extend the useful life of your lights. Did I mention the lights are always subject to the full heat of your beautiful sunny days as well as the full fury of your dreadful rainy season? BTW, we visit often and love Florida.
I hope this information helps you.
Thanks for using FixYa.com
please vote
thanks
a
Dec 05, 2009 | Washing Machines
My camera turns on then quickly turns off.
This is usually a low/bad battery problem. Remove the batteries from your camera and make sure the battery and camera contacts are clean. If using alkaline batteries, try a fresh set. If using rechargeable batteries, recharge them for several hours. If a recharge doesn't work, you may need a new battery set. eBay is a good source for reasonably priced replacement batteries.
Bill B.
San Antonio
May 16, 2009 | Kodak EasyShare DX6490 Digital Camera
kawasaki PVS-10921 Portable DVD Player Logo
44 people viewed this question
Top kawasaki Televison & Video Experts
wayne chamberlain
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
