Question about AudioBahn AW100T Car Subwoofer
Subwoofer sound interference
My subwoofer in my car is having major interference... it sorta of a rumbling sound when the cd players doing somthing like when the disk is spinning and it used to make a "poinging" sound every 1 second or so but its sorta stopped but it still does it sometimes please help?!
    Problem Solver:
  • 10 Answers
It sounds like you may have unshielded patch cable (rca cables) or they may be coming loose from either the head unit or at the amp which could cause the same thing and it may also have a cut in the cables but in my opinion it has to be the head unit or the patch cables cause there shouldnt be anything else in your car that would cause that phenomenon. more than likely the cables are loose at the head unit in my opinion if you have another amp available to you i would try it and see if it reoccurs if it does and most likely will you need to take out the unit and if the cables are completely in you could have 2v preouts which sometimes in conjunction with other factors seems to cause also
sorry i couldnt just tell u whats wrong
justin
Posted on May 22, 2009
HI my name is simon from zambia,i'v had this problem for quite a while now,my subwoofer keeps making this funny rumbling irritating sound what should I do about it? Please help.
If your subwoofer is self-powered, turn down its volume control. Also, the rumbling can be caused by placement near objects that inturn can vibrate. Sup woofers are non diretional and therefore easily relocated. Also, try placing the subwoofer unit on a piece of carpet. This will stop any vibration picked up by the floor.
Jun 05, 2011 | Creative Labs Audio Players & Recorders
No sound from my Yamaha YST-SW315 subwoofer. When I run the test speakers don't have sound either. Not sure if its the subwoofer or the Yamaha RX-V450 receiver
Feed it with an RCA cable any other audio device you may have (CD, TV, MP3 player, PC) to prove it can or can not woof. It will respond to any audio, not just LFE or subwoofer audio.
Apr 14, 2011 | Yamaha YST-SW315 Subwoofer
How can i conect my subwoofer to this cd player?
if the cd player have subwoofer output it is easy connect from cd player output wire red and white to input subwoofer red and white
Aug 07, 2010 | Pioneer DEH-1600 CD Player
Sony subwoofer shuts down then restart, possible overheating
If that is a amplified sub(should be)it sounds like a bad mosfet chip on the heat sync.
Oct 27, 2009 | Audio Players & Recorders
When no music is on the subwoofer makes low rumble sound
It's passing "engine noise" at 80hz and below. If you turn off the crossover on the amp, it will be unbelieveably loud. Check your RCA connections at the deck and at the amp. Then make sure your ground wire to the amp is solid and not oxidized. Check your battery terminal as well. Make sure your ground wire is the same gague as the power, and that it's grounded to the floor, not a seat bolt or side panel, as they are very poor grounds. Hope this helps. If you still have an issue, post a comment and I can help some more.
Jul 01, 2009 | Kicker CVR12 Car Subwoofer
Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Jun 06, 2009 | JVC KW-AVX800 CD Player
Need advice on how to disgise subwoofer box in sound competition
Fabricate a fake box over the pvc port to hide it. Goodluck.
Oct 24, 2008 | Pioneer AVIC-N2 Car DVD Player
Not satisfy with the sound of my system
This Unit has got a 4x60w amp built in.
On it's own the subwoofer will not work, you need to buy a Monoblock amplifier, a wiring kit and a set of RCA leads to run it.
The RCA leads plug into the SUB output RCA sockets on the back of the headunit.
The OEM speakers in your car will not be of great quality, so it would be wise to change them. If you do, you need to buy speakers that have a rating of no less than 90watts, any thing less and they will sound distorted.
Any car audio shop will be able to help you select the right size and rating to suit your car. They may even fit it all for a charge.
Hope this helps
Regards
DarkmanUK
Please remember to rate.
Aug 16, 2008 | Pioneer DEH-P80MP CD Player
Subwoofer shutdown
I'm having the same issue as pdoug: Sub rumbles in test mode, doesn't produce sound otherwise. Which makes me suspect it's the receiver itself -- the filter (or whatever) it is that should be separating the bass signal and sending it to the sub is not working. At least that's my guess.
Either way... this sucks.
Mar 14, 2008 | Kenwood VR-407 Receiver
NO Sound Except Subwoofer on Disk Playback
guys wrong iso adapter.go to propper audio shop
Oct 11, 2006 | JVC KD-AVX2 Car DVD Player
AudioBahn AW100T Car Subwoofer Logo
474 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
