Question about Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi saying GPS SW version 4.10software 7.10 what does this mean
Do not know enough about setting it
marcelbakker
  • 174 Answers
SOURCE: Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
So what happens when you connect it to the PC?
Make sure no sd cards are installed while you do this.
download and install web updater, run it it gets to a screen where it looks for the gps, plug the usb cable into the GPS (no USB hubs please!!!) Make sure it detects the GPS before you continue. Select the updates you need (don't install all the languages !!) after this is done the program will report the downloads are on the garmin, unplug the unit and it will reboot and whilst rebooting it will install the updates....so don't touch it until it reboots again and displays the regular screen....and make sure the batery is fully charged before you do this...!
Posted on Jul 23, 2008
  • 638 Answers
SOURCE: Broken Garmin GPS Nuvi 300 Touch Screen
I know of this site where your screen can be replaced.
http://www.sharc.net/nuvi_LCD_repair.htm
Posted on Jan 08, 2009
SOURCE: My Garmin Nuvi 710 GPS doesn't switch on
Connect your Nuvi to a PC using a USB and then hold the switch to the left for 15 seconds. It should then power up after a soft reset
Posted on Oct 10, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi Doesn't turn on
Try resetting the unit. The procedure can be found here:
http://www.sharc.net/discus/messages/6/313.html?1268661443
- Jim
Posted on Mar 19, 2010
popsgifts
  • 160 Answers
SOURCE: locked out of Garmin nuvi
To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1200,1300,1400 or 1600 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings. If you would like to back up your favorites you can find instructions to do so here.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 19, 2010
Hi, My Garmin nuvi displays 'gps is off' which means i am unable to de directed correctly as its saying im in the middle of no where. Please can you help? Thank you Laura
There are two possibilities as to why your GPS is not responding.
The first is to check your System Settings. Although it should not affect your GPS signal, check to see if the WAAS / EGNOS setting was turned off. If so, try turning it back on.
The other possibility is that the Garmin device is not reporting the status of your antenna properly. When the Antenna is closed on the nuvi 350, it disables the GPS functionality. Simply open the antenna to re-enable GPS. If the antenna IS open, there could be a hardware malfunction. This would require contacting Garmin for additional assistance.
Contact details for Garmin can be located at http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 27, 2011 | Garmin nuvi 350 GPS Receiver
I have a garmin gps nuvi 255w and I wanted to register it, but a massage keeps on poping up saying external power lost shuting in 29 seconds.What should I do?
Try to charge your nuvi properly and full, or for at least 2hours before registering it. If the source of power connected to your nuvi is not strong enough, the nuvi might go off during an operation. Secure that the battery is well charged, then the source supplying the power is good enough to supply your nuvi with power before starting an operation.
Hope this helps.
Dec 24, 2010 | Garmin nuvi 780 GPS
NuviĀ® 255W Car GPS Receiver: I received the Garmin nuvi 255W for Christmas but ...
Microsoft Streets &Trips might not recognize your GPS unit. I found that my latest S&T version only recognizes Microsoft's own GPS puck.
May 18, 2010 | Garmin nuvi 255W GPS Receiver
Getting to a specific address
Next time you want to go to a specific address, do not enter the city. Instead, hit "Search All". Then enter the address as normal. Sometimes the address is listed as being in a different/nearby city due to the ZIP code. Let me know if this helps.
Apr 10, 2010 | Garmin nuvi 205W GPS Receiver
SW Version Saying 0.00
that's because of the map you have to updata the map and you have to download the quick gps fix
Apr 21, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 660 + omnia
Hi, version 3.1 is supposed to help with disconnects. Please see this link:
http://www.gpspassion.com/FORUMSEN/topic.asp?TOPIC_ID=109459
However, Garmin released 3.4 which will include the changes in 3.1 and also makes the bluetooth compatible with more phones.
You need to go to www.garmin.com and download their webupdater and run it with your Nuvi connected to the PC with a USB cable. It will check (via the Internet) if you need a firmware upgrade. The latest firmware version for a Nuvi 660 is v4.7. There is a second menu after the main firmware option that allows you to select additional software. Select yes and check the bluetooth 3.4 box and the Chipset "G" box if it's shown.. The Chipset "G" is the upgrade for the receiver in the flip-up antenna. Let it download. When finished, select to safely remove the Nuvi. You can now unplug the USB cable. Your Nuvi will reboot and load in the new changes. Whatever you do, don't turn your nuvi off! Let it go and update. You will see it say "Loader", then "Loading Software" and you'll see a task bar that says "Updating Bluetooth Software" and "Updating GPS Software" (if required). Once you get to the main menu and there are no more texts coming up on the screen. Press the power button and turn your unit off and then back on again. Check the GPS and Bluetooth firmware versions in your Nuvi. It should be 3.0 for the GPS and 3.4 for the Bluetooth. Check the firmware version if you selected v4.7. You will have to re-pair your phone with your Nuvi as the update erases any previous set-up. Let me know how it went for you. If you have trouble with this, let me know. I can do it for you. I have done it many times. Please rate my solution if you found it helpful.
- Jim
SHARCNET-USA
Jan 06, 2009 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 310 which wont pick up satelites the gps software version is 0.00 i need to find out what the proper version is and where to get it and how to install it
Go to the Garmin website and download their Webupdater program. Run it and plug your Nuvi into the PC using the USB cable. It will upgrade your Nuvi firmware and then ask if you want to select other software. Select the one labeled GPS chipset G. After it has finished, make sure you deselect the Nuvi and unplug the cable. The Nuvi will reboot and say "LOADER" and will reboot with the latest firmware and attempt to update the GPS software to v3.0. After it has rebooted, turn it off and then on again. Check the GPS software version. It should be 3.0. If it's still 0.0, then your antenna/receiver is bad and needs to be replaced.
- Jim
Nov 14, 2008 | Garmin GPS
N?vi 350
mumbo jumbo....use the webupdater, check the firmware and voice/text you need, the web updater will download them to the nuvi, when downloaded webupdater will tell you, unplug the nuvi and wait patiently for it to reboot about twice....finished.
Jun 19, 2008 | Garmin nuvi 350 GPS Receiver
GArmin Nuvi 360 - bluetooth not working right
Wow, as soon as I got my nuvi 360 I turned the Bluetooth off. I then updated to 4.40 and the bluetooth SW version is now 0.00 and i cant even enable the bluetooth again. I think we have the same problem. I wish I could help but I am in the same boat.
Dec 24, 2007 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi 350 Car GPS Receiver Logo
22 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
